Thread: Strange/alarming intermittent vibration through steering wheel ??
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Exclamation Strange/alarming intermittent vibration through steering wheel ??
    Whilst driving home tonight I had a bit of a scare.
    With no warning I felt a tugging vibration through the steering wheel which lasted about 10seconds. My first thought was puncture but when I stopped and checked everything was fine. I have had one of the front wheels off recently so I then checked to make sure the wheel was not loose but again all was fine. I then checked the steering and to see if there was any play in it and it was ok.
    Satisfied that my wheels were not about to fall off I continued my journey home, on the way it did it twice again in the space of five minutes. It feels like something is waggling the steering wheel in my hands.It did it at roughly 40 and 30mph so it does no seem speed related.
    I can't really do much as it is pitch black outside at the moment but does anyone have any ideas as to what is going on ??
  2. Re: Strange/alarming intermittent vibration through steering wheel ??
    Jun 2012
    Nottingham
    Sound strange. Any knocks from the suspension of recent? Knocks through the steering going lock to lock at parking speeds? Uneven tyre wear?
  3. Re: Strange/alarming intermittent vibration through steering wheel ??
    Aug 2011
    Meath
    Any warning lights on ?
  4. Re: Strange/alarming intermittent vibration through steering wheel ??
    No warning lights on, the tyres are worn evenly about 4-5mm above the wear indicators. I have not hit any especially large pot holes recently that I noticed but I did about 2 years ago and that killed a tyre on the front nearside but I had the tracking checked afterwards at it was ok.
    The only thing of note was that I took off the offside front wheel to check the disc size as I am replacing them soon but that was last week. Tonight wast the first time its done this.
  5. Re: Strange/alarming intermittent vibration through steering wheel ??
    I tried the steering lock to lock turning round a the top of the road and it was smooth with no play, no vibration under braking either.
  6. Re: Strange/alarming intermittent vibration through steering wheel ??
    Aug 2011
    Meath
    It could be the power steering pump is there fluid in the reservoir ?
    1 1 0
  7. Re: Strange/alarming intermittent vibration through steering wheel ??
    Just went and had a look with the torch, plenty of fluid, half way between max and min.
  8. Re: Strange/alarming intermittent vibration through steering wheel ??
    Pembrokeshire
    22 Post(s)
    that wheel that took a clout, i would be taking that off and thoroughly checking it for damage and cracking. if thats ok, then i would be putting the car in the air and checking all front axle components.
    1 1 0
  9. Re: Strange/alarming intermittent vibration through steering wheel ??
    Aug 2011
    Meath
    I'd take the tension off the drive belt and check the steering pump is spinning freely. Did it feel like ABS was on? Any bilge on the tyres?
  10. Re: Strange/alarming intermittent vibration through steering wheel ??
    Quote Originally Posted by Doctle Odd View Post
    No, if you imagine someone grabbing hold of the steering wheel and tugging it quickly side to side that's what it felt like nothing through the pedals.
    I plan to get the car up on axle stands tomorrow and have a good look see. I will try releasing the tension on the belt as suggested to.
    If there is nothing to see I will test drive it and see if it happens again.
  1. steering wheel vibration
    By DSGboy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-05-2015, 11:49 AM
  2. Vibration through pedals and steering wheel
    By swsteve in forum Early Passat Forum - Pre 97
    Last Post: 19-04-2009, 03:22 PM
  3. Steering wheel rattle/vibration
    By A4OBAN in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-09-2008, 09:08 AM
  4. Polo 1.3 steering wheel vibration
    By redimp in forum Polo - Derby - Lupo - Fox
    Last Post: 15-03-2008, 10:39 PM
  5. steering wheel vibration
    By ian in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-02-2007, 05:22 PM
