Thread: VW Radio Code
  1. VW Radio Code
    Aug 2007
    Hi there
    I am now watching two types of VW Radio and Cassette Player, one is Gamma, the other is Beta.
    I perceive that Gamma one needs security code when power is lost, and not sure whether it's the same for Beta one? Anyone knows?
  2. Re: VW Radio Code
    Dec 2006
    Wiltshire
    They both need codes, and the only easy way to obtain them is through a VW dealer.
    They can be decoded but you need to take them to a specialist for reprogramming.
    A6 (2007)TDi SE Avant
    Gone but not forgotten - A4 2.5TDi Avant, Imola Yellow S3 , Golf VR6 Highline
  3. Re: VW Radio Code
    Aug 2007
    ICIC
    that's the reason why someone said it's ok when moving from his friend car to his, but someone said code is required, regardless the type of radio.
    BTW, decode means remove the code permanently or just reset the code to something like 1111?
  4. Re: VW Radio Code
    Mar 2007
    Greater Manchester
    Quote Originally Posted by inbritain View Post
    ICIC
    Generally speaking, to decode means to decipher or work out the code.
    The dealers would find out what your code is and then tell you.
    Funnily enough I was reading the handbook of my radio yesreday and it said if you loose your code then VW dealer can get it for you for free. Don't know if that's still the case.
    Have a look at post 9 here https://www.vwaudiforum.co.uk/forum/s...ad.php?t=10373
    it tells you the main difference between Gamma and Beta
    2001 Bora TDi PD 115 (AJM)
  1. radio code
    By nerrad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-07-2007, 11:17 PM
  2. VW Radio Code
    By ian999 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-05-2007, 09:52 PM
  3. Inputting Radio code
    By ferrispedro in forum Touran - Sharan - Caravelle
    Last Post: 01-02-2007, 06:45 PM
  4. Audi Radio Code
    By eribar in forum Archive posts
    Last Post: 30-06-2006, 11:07 AM
