Thread: Wet passenger footwell
Results 1 to 10 of 11
  1. Wet passenger footwell
    Aug 2012
    Southampton England
    Had this with my passat... Any ideas??
  2. Re: Wet passenger footwell...
    Pembrokeshire
    22 Post(s)
    no, there has never been an instance of any passat having a wet passenger footwell. i have no idea what could be happening
    maybe, just maybe its a blocked plenum drain.
    2 2 0
  3. Re: Wet passenger footwell...
    Feb 2009
    Glasgow UK
    Door seals or perhaps check your pollen filter / plenum drains?
    Good luck
  4. Wet passenger footwell...
    Aug 2012
    Southampton England
    Blumen VAG! I thought this would be sorted by now! Hey ho! Thanks guys
  5. Re: Wet passenger footwell...
    Jan 2011
    Chester
    take your battery out and clean out the hole thus......
    C5 S6, B5 RS4, 8L S3, T5 Cali, B7 A4 3.0tdi, B4 S2, C3 100 and a few others....
  6. Re: Wet passenger footwell...
    Jan 2010
    kent, england
    10 Post(s)
    Had a similar experience myself this weekend. Heard a sloshing sound when.cornering, had aoil the next day and the battery area had 6 inches of water in it! Found a large plug under the battery and removed this to drain. Have left it out for.the.time being as I've not a chance.to take a proper look. Are the drain holes hard to find?
  7. Re: Wet passenger footwell...
    Dec 2009
    southampton uk
    Thats one the other is near the servo
  8. Re: Wet passenger footwell...
    Jul 2006
    my A4 had this. Removed the battery and the plastic tray underneath it. found loads of old leaves and rubbish, cleared those and the drain holes under the servo (can be seen in the picture posts above) and the opposite side by poking a screwdriver in there in the lowest most part of the panel. The one immediately under the servo was the the worst by far - when it cleared soooo much water came out. Not been an issue since.
    2005 Audi A4 S-line 2.0tdi Avant
  9. Re: Wet passenger footwell...
    1841 Post(s)
    What, water in the passengers footwell of an A4! Bloody hell! never herd of that one...
    0 2 0
  10. Re: Wet passenger footwell...
    Aug 2012
    Southampton England
    Thanks all! It is just the same as my Passat! They covered the whole repair including a new CCM.
    Is it in danger in the A4 or did they learn and put it above the water line?
  1. passenger footwell soaking wet
    By Kris G in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-02-2014, 06:03 PM
  2. Wet carpet in passenger footwell??
    By Midnightsky in forum Bora - 1998 - 2005
    Last Post: 25-12-2009, 09:41 PM
  3. Wet Passenger Footwell
    By Evoblade in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-02-2009, 11:35 AM
  4. Please Help Wet passenger footwell, any suggestions?
    By alba_tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-01-2009, 11:41 PM
