Thread: ABS brake problem?A4 Avant 1.9tdi 1998
Hybrid View
  1. ABS brake problem?A4 Avant 1.9tdi 1998
    Mar 2007
    I've had problems in the past with ABS light on, apparently the sensors were trying to read a loose ring. This resulted in a hideous grinding, lack of braking efficiency and the effect of the pedal pushing back at you when you brake hard. Eek!
    I got that sorted and only had it mildly (now and then) when pulling up to a stop, until now. Whether connected or not (after replacing the rear caliper seal and piston) it's back. BUT no ABS light and it only occurs on violent emergency (test) braking. If I firmly brake over approx 200yds (ish) it doesn't occur. Hmmm.
    But when it does...(!) it's a bit disturbing.
  2. Re: ABS brake problem?A4 Avant 1.9tdi 1998
    46 Post(s)
    Get it scanned for faults!
  3. Re: ABS brake problem?A4 Avant 1.9tdi 1998
    Pembrokeshire
    22 Post(s)
    sounds like an air gap too large. the distance between the sensor and the ring. if its too big the sensor kicks in and then the abs does its thing, thinking a wheel has locked. you can check this in live readings, seeing which sensor drops off to 0, or by connecting an oscilloscope to each sensor and seeing what happens.
  1. Question A4 1.9TDI SE Avant 1998 - Clutch Issue
    By wild01 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-09-2011, 08:12 PM
  2. Please Help A4 1.9TDI SE Avant 1998 - Starter Motor Removal
    Last Post: 14-04-2011, 02:49 PM
  3. A4 estate 1.9TDI SE 1998 rear brake discs issue!
    By shaunlfc1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-10-2010, 01:53 PM
  4. A6 Avant - ABS ECU or brake switch?
    By stan still in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 01-04-2009, 11:39 PM
  5. 1998 A6 1.9TDI Auto Avant. Vibrations around 50mph
    By Mike Singleton in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-12-2008, 02:29 PM
