Thread: A6 3.0 TDI QUATTRO numbers
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 54
  1. Re: A6 3.0 TDI QUATTRO numbers
    Sep 2011
    Lurking over a keyboard ...
    The clutch generates briefly (about 500 ms) noises or vibrations/juddering when changing gear.
    Note: This entry only applies to vibrations/juddering during the control phase of the converter clutch.
    The converter condition can be checked in MVB 007/3 (converter open/ convertercontrol/ converter shut).
    Above is extract from a technical service bulletin... I don't think this particular TSB apply to your car as it is newer... but you can see diagnostics can be done without removal of tranny...
    Get some diags done on tranny... if you PM an external email I will send you the PDF...
  2. Re: A6 3.0 TDI QUATTRO numbers
    Nov 2012
    Australia, Melbourne
    Sent you email, thanks mate
  3. Re: A6 3.0 TDI QUATTRO numbers
    Nov 2012
    When i turn on the car i hear liquid bubbling from the engine compartment.... Anyone had any similar sounds? What could it indicate? Very curious. Also i noticed revs more bumpy when that is happening. Come to think of it, when they scanned it a coolant error came up previously. Would that somehow have anything to do with the weird bubbling sound? Any help appreciated!
  4. Re: A6 3.0 TDI QUATTRO numbers
    Southern County Softy
    20 Post(s)
    Quote Originally Posted by Cwizard View Post
    Sounds like a blocked Plenum drain.
    ....If only I was as smart as this bloody phone
    A4 2.5 tdi QS (mapped)
  5. Re: A6 3.0 TDI QUATTRO numbers
    Nov 2012
    Could be, but why would it make that sound only when i turn on the engine? Including the revs being more bumpy. Maybe water pump? I'm out of ideas.
  6. Re: A6 3.0 TDI QUATTRO numbers
    Nov 2012
    Here it is, could anyone indicate to me what is causing revs do jump around while driving?
    VCDS Version: Release 11.11.4
    Data version: 20120807
    Saturday,22,December,2012,17:24:10:36977
    Chassis Type: 4L0
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61
    62 6C 72 76 77
    VIN: oops! left it here earlier Mileage: 130590km/81144miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F0 910 402 D HW: 4F0 907 401 C
    Component: 3.0L V6TDI G000AG 0020
    Revision: --H03--- Serial number:
    Coding: 0011372
    Shop #: WSC 02334 785 00200
    VCID: 1E33176FC927A4E8339
    4 Faults Found:
    005658 - Glowplug for Cylinder 1 (Q10)
    P161A - 001 - Open Circuit
    Freeze Frame:
    Fault Status: 01110001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 129989 km
    Time Indication: 0
    Date: 2012.12.09
    Time: 11:12:28
    Freeze Frame:
    RPM: 882 /min
    Torque: 97.5 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.91 V
    Duty Cycle: 24.9 %
    Temperature: 25.2°C
    005659 - Glowplug for Cylinder 2 (Q11)
    P161B - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 129989 km
    Time Indication: 0
    Date: 2012.12.09
    Time: 11:12:28
    Freeze Frame:
    RPM: 882 /min
    Torque: 97.5 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.91 V
    Duty Cycle: 24.9 %
    Temperature: 25.2°C
    005660 - Glowplug for Cylinder 3 (Q12)
    P161C - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 129989 km
    Time Indication: 0
    Date: 2012.12.09
    Time: 11:12:28
    Freeze Frame:
    RPM: 882 /min
    Torque: 97.5 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.91 V
    Duty Cycle: 24.9 %
    Temperature: 25.2°C
    005661 - Glowplug for Cylinder 4 (Q13)
    P161D - 001 - Open Circuit
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 129989 km
    Time Indication: 0
    Date: 2012.12.09
    Time: 11:12:28
    Freeze Frame:
    RPM: 882 /min
    Torque: 97.5 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 13.91 V
    Duty Cycle: 24.9 %
    Temperature: 25.2°C
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F2 910 156 F HW: 09L 927 156 C
    Component: AG6 09L 3,0 TDI RdW 0030
    Revision: --H01--- Serial number: 4218947
    Coding: 0000001
    Shop #: WSC 02325 785 00200
    VCID: 285F31B79B636A58495
    No fault code found.
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
    Component: ESP8 quattro H01 0070
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020872
    VCID: 66C37F8F51F7BC28BB9
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0220
    Revision: 31050601 Serial number: 10601000507697
    Coding: 0000019
    Shop #: WSC 02323 785 00200
    VCID: E3C5E69B22C54900DC7
    Part No: 4F0 910 131 A
    Component: FBSAUDIC6 EZS H45 0080
    Part No: 4F0 910 220
    Component: FBSAUDIC6 IDG H01 0040
    Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
    Part No SW: 4F0 910 731 K HW: 4E0 035 729 A
    Component: Interfacebox H43 2860
    Revision: 00000000 Serial number: 351HN067524172
    Coding: 0000002
    Shop #: WSC 02335 785 00200
    VCID: 2A5BCBBF856F58485F1
    Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H02 0060
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F2 820 043 M
    Component: KLIMABETAETIGUNGH20 0170
    Revision: 00000031 Serial number: 00000000297899
    Coding: 0009302
    VCID: DBB5DE7B1AB571C0947
    1 Fault Found:
    00739 - Coolant Circulation Pump (V50)
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 240
    Mileage: 130072 km
    Time Indication: 0
    Date: 2012.12.09
    Time: 13:00:21
    Freeze Frame:
    Temperature: 89.0°C
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 L HW: 4F0 907 279 B
    Component: ILM Fahrer H17 0240
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0010101
    VCID: 326BD3DFADBF1088E71
    Subsystem 1 - Part No: 4F2 910 113 A
    Component: Wischer AudiC6 H04 0190
    Coding: 00064784
    Shop #: WSC 02335
    Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
    Component: REGENLICHTSENSORH13 0090
    Coding: 00146221
    Shop #: WSC 02335
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
    Component: CD-Changer H44 0470
    Revision: 00000000 Serial number: AUZ5ZBF8171789
    Shop #: WSC 00000 000 00000
    VCID: 1C371D67DF3BB6F8DDD
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 4F AIRBAG AUDI8RH29 0280
    Revision: 08H29000 Serial number: 0037LD0G6JLK
    Coding: 0013382
    VCID: 295934B38069535056B
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H08 0230
    Revision: 00H08000 Serial number: 90055062090034
    Coding: 0102141
    VCID: E6C3FF8FD1F73C283B9
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H07 0090
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 900 C HW: 4F0 920 901 C
    Component: KOMBIINSTR. M73 H12 0110
    Revision: 00200000 Serial number: 58U746086
    Coding: 2049743
    Shop #: WSC 32200 522 175670
    VCID: 204F2997F3539218015
    Address 19: CAN Gateway Labels: 4L0-910-468.lbl
    Part No SW: 4L0 910 468 HW: 4L0 907 468
    Component: J533__Gateway H06 0040
    Revision: 00H06000 Serial number: 0900B068078112
    Coding: F551DE57301206
    VCID: ECD78DA7CF1B06786DD
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0120
    Revision: 00000000 Serial number: eA†
    Coding: 0000634
    Shop #: WSC 02327 785 00200
    VCID: 2C57CDA78F9B4678ADD
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
    Component: Komfortgeraet H22 0170
    Revision: 01700022 Serial number: 01017470990000
    Coding: 0271753
    Shop #: WSC 31220 822 81281
    VCID: 2E53C7AFB9873468839
    Address 47: Sound System Labels: 4F0-910-223-AS.lbl
    Part No SW: 4F0 910 223 G HW: 4F0 035 223
    Component: Amp.-ASK H10 0350
    Revision: 44S00001 Serial number: 02607060327518
    Coding: 0000003
    VCID: 224B239FFD5F8008171
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000266953
    Coding: 0001013
    VCID: DEB3D76F09A764E8F39
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0120
    Revision: 00000000 Serial number: a4†
    Coding: 0000634
    Address 53: Parking Brake Labels: 4F0-910-801.clb
    Part No SW: 4F0 910 801 B HW: 4F0 907 801 A
    Component: EPB CB4C0060 H04 0060
    Revision: --H04---
    Coding: 0000321
    Shop #: WSC 02324 785 00200
    VCID: 1F4D2A6BCE2DADE038F
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 M HW: 4F0 035 541 H
    Component: TUNER EU/US/RDW H42 0570
    Revision: 00000000 Serial number: 394H 067673175
    Coding: 0000001
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000088004
    VCID: 2345269BE24589001C7
    Subsystem 1 - Part No: 4F0 915 105 D
    Component: von VA0 0607311758
    Coding: 344630393135313035442056413030363037333131373538
    Shop #: WSC 00000 384 00290
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0050
    Coding: 0000042
    Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
    Part No SW: 4F0 910 441 HW: 4L0 907 441 A
    Component: J772__Rearview 0050
    Revision: --H12--- Serial number: 525PA8-J6820AS
    Coding: 1020204
    VCID: DDB1D06304A17FF0EA3
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0050
    Coding: 0000042
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
    Component: Parkhilfe 8-Kan H12 0060
    Revision: 00H12000 Serial number: 06320620903153
    Coding: 0221006
    Shop #: WSC 131071 1023 2097151
    Address 77: Telephone Labels: 4E0-910-336.lbl
    Part No SW: 4E0 910 336 M HW: 4E0 862 335
    Component: Handyvorb2 H18 1130
    Revision: 00000000 Serial number: 00000005087601
    Coding: 0010920
    Shop #: WSC 03122 822 81281
  7. Re: A6 3.0 TDI QUATTRO numbers
    #17
    Nov 2012
    just terrified this might happen!
    http://forums.tdiclub.com/showthread.php?t=329283
  8. Re: A6 3.0 TDI QUATTRO numbers
    #18
    Sep 2011
    After looking at that linked thread my reaction was ... I agree with view in that thread that some heat issue must have caused the GP's to go like... considering GP's are cheap at a certain age it maybe wise to just replace so they are at their best...
    Back to your log...
    RE glowplugs if you clear fault has it come back?
    RE your gearbox/TPI...
    Ref the table in TPI you will see parts no/revision for software, your P/N above in red, your rev above in blue...
    If you view gearbox from below there is plate with its number on... if you number is higher than one in TPI you can disregard TPI as not applicable...
    RE 00739 - Coolant Circulation Pump (V50)
    Fault frequency is 4, to do physical check view under plenum chamber cover... here is link to some info and image to ref against when viewing in PC... Link:- V50 Audi A6 4F
    Has fault returned after clearing? if it has returned I've seen a thread where someone refurbished their one rather than replace it...
    You may find it if you search on VWAF... if I find will post link... this thread has some viewpoints on related fault Link:- https://www.vwaudiforum.co.uk/forum/s...ult-code-00739
    I hope your fix is economical... they are lovely cars just so ££££ to sort an issue...
  9. Re: A6 3.0 TDI QUATTRO numbers
    #19
    Nov 2012
    Thanks so much for the detailed info, i don't have the equipment to get the car up. Also how much would a Coolant Circulation Pump (V50) cost? Just a rough estimate, can't find one on ebay.
  10. Re: A6 3.0 TDI QUATTRO numbers
    #20
    Sep 2011
    My usual PC PSU blew up... so no access to data... will soon rebuild and get you P/N & price... maybe someone else will pop along with info...
    Guessing by your post in glow plug thread the fault comes back on glow plugs then?
  1. 1.6s tdi non bluemotion vs 1.6 blumotion. lower suspension part numbers.
    By jahilton2002 in forum Golf MK6 - 2009 - 2013
    Last Post: 14-05-2012, 02:50 PM
  2. remap on 3.0 tdi - real numbers?
    By acabucca in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-04-2010, 09:05 PM
  3. 07 Passat 2.0 TDi ABS unit, how strict are part numbers??
    By chodecz in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-10-2009, 07:21 PM
  4. 2.5 tdi oil mist separator part numbers
    By mhobson in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-08-2009, 02:56 PM
  5. 115 Bhp Gt Tdi Turbo Numbers!!
    By benzo in forum Golf MK4 - 1999 - 2004
    Last Post: 15-03-2008, 07:56 PM
