Thread: Cambelt tensioner bolt shear and camshaft wear
  1. Cambelt tensioner bolt shear and camshaft wear
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I have just had the cambelt tensioner bolt shear on my 2002 Audi A6 2.5TDI with 102K miles. I am waiting for the bad news, but what is even worse is that the camshafts are severely worn. This is incredible as I have been changing my oil every 11,000 miles with longlife 506.00 spec oil. Has anyone experienced either of these problems.
    Audi A7 3.0TDi 2011 180k miles, engine code CLAB 204bhp 2WD
  2. Re: Cambelt tensioner bolt shear and camshaft wear
    Mauritius
    My car went to the Audi garage after 2 months of starting problem. Although its an A4 1.9TDI Yr 2001 with 148000kms, I would think it looks more to happen in a diesel engine. My car has always been serviced by the Audi dealer so I guess the correct oil was changed at the 10000km interval.
    One Cam lobe had more than 10mm wear and the others about 4-5mm seen with the eye. Looks like this
    http://www.sacskyranch.com/camshaft.htm
  1. Upper hub bolt - siezed?
    By vwmark in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-05-2008, 05:59 AM
  2. Mk2 camshaft timing belt marks
    By dannyholmes in forum Golf MK2 - 1984 - 1992
    Last Post: 25-08-2007, 11:31 PM
  3. A4 Rear Bulb- bolt doesn't come out??
    By lindag in forum Audi A4 - Archive Topics
    Last Post: 16-11-2006, 03:00 AM
  4. bolt pattern
    By stuvette in forum Chat - Completely Off Topic
    Last Post: 05-06-2006, 09:30 AM
  5. Cambelt & Tensioner replacement on Passat
    By PaulwithPassat in forum Archive posts
    Last Post: 22-02-2006, 05:39 PM
