Thread: Parking sensors OEM
Results 1 to 10 of 11
  1. Parking sensors OEM
    Nov 2012
    North Somerset
    Guys do Audi OEM parking sensors come ready painted or are they painted by the dealer and fitted by the dealer?
    Also hoe easy are they to fit?
    A6 C6 Avant TDI, de-Badged, LED side lights, LED numberplate lights not just bulbs! so far!!
  2. Parking sensors OEM
    46 Post(s)
    Not sure but I'm guessing probably not.
    Remember you'll need the sensor loom, control module and relevant wiring to incorporate it into the MOST/CAN systems in the car.
    You would be better fitting the Cobra Sensors which are flush with the bumper and only require the reverse light pick up Cobra Flush Parking Sensors - Colour Coded | eBay
    I can vouch for the above seller - highly rated.
  3. Re: Parking sensors OEM
    Sep 2011
    Lurking over a keyboard ...
    Quote Originally Posted by ChA6dders View Post
    Also how easy are they to fit?
    They come in about four colour codes only pre painted and unpainted... looking at your side light guide yours is same colour code as my car... sorry computer say no to that being pre painted ... you'll also need a bumper with PDC holes...
    My car had factory fit rear PDC but no graphical display ie the sonar lines... got module off ebay for £30... seen looms for about under £20... I was also able to grab unpainted sensors set of 4 for £40 off ebay (Brand new )...
    As to retrofit them off the top of my head member Kerbdog done them on his car... Link:- VW AUDI Forum - VWAF
    I can help with the coding part and double check P/N's for you ...
  4. Re: Parking sensors OEM
    Nov 2012
    North Somerset
    Gup
    PM sent ;-)
  5. Re: Parking sensors OEM
    Nov 2012
    North Somerset
    That's alot of money Chris but thanks for the input
  6. Parking sensors OEM
    46 Post(s)
    When you factor in the cost of the OEM setup it's relatively cheap.
    It's what Audi dealers use to retrofit them to cars.
  7. Re: Parking sensors OEM
    Sep 2011
    The ebay link is good value... £199 is list price... when part no is searched it hits A6 2005-2008 and 2009 -2011...
    Looks spot on mate... yes factory fit ones are flusher but on value for £££ and fitting I would be inclined to go for that Audi kit...
    My mate has those on his A4 Avant 55 plate... you really can hardly tell that they are sitting on bumper unless you are really looking... if you get what I mean...
    I don't know if you get the sonar lines on MMI red screen but gotta say that helps more than just the beeping and IMO better than the camera setup...
  8. Re: Parking sensors OEM
    Nov 2012
    North Somerset
    Quote Originally Posted by gupsterg View Post
    Cheers mate will painting them effect the signal I'd probably do a few coats of primer if needed then the actual colour
  9. Re: Parking sensors OEM
    Sep 2011
    Yep I sprayed mine at home... good result via doing like a waft motion at distance on them and doing a few coats, I got away without a primer... some good guides on the net have a google...
  10. Re: Parking sensors OEM
    May 2015
    Cardiff
    Hi Chris, gupsterg, all members reading this, I completed a PDC retrofit on an Audi A5 2008 (already had rear audible sensors) now have graphics, reverse camera, front & back sensors. All working except the aps switch which lights up when activated (by putting in reverse gear) but no way of activating/deactivating the front sensors except when speed goes above 5mph. Does anyone have any idea what pins to connect to the parking control module. I used the Kufatec guide and pin outs not correct. Happy to help anyone with PDC retrofit and post my guide up here (put on a5oc.com). Thanks
  1. Parking Sensors
    By westfield1962 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-05-2011, 09:12 PM
  2. Parking Sensors with non oem Headunit.
    By kaboom1 in forum Golf MK6 - 2009 - 2013
    Last Post: 03-05-2010, 05:26 PM
  3. OEM Parking Sensors
    By mabela in forum Passat CC
    Last Post: 29-12-2009, 06:58 PM
  4. parking sensors
    By nug402 in forum Golf MK5 - 2004 - 2009
    Last Post: 09-08-2008, 05:55 AM
  5. Looking for an OEM/Second Hand Parking Sensor System
    By bobmac892 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-02-2008, 09:25 PM
