Thread: 2001 Passat 1.9 TDi vacuum hose diameters and lengths
  1. 2001 Passat 1.9 TDi vacuum hose diameters and lengths
    Nov 2012
    Gwynedd, UK
    I've bought some 3mm inside diameter vacuum hose but the inside looks tiny compared to the smallest of the original rubber tubing already on the car. Have I got the right size? Just a bit concerned in case it's too small and will restrict how fast valves can be pulled open. What I'm considering to be the smallest tubes are ones that go to the anti-shudder valve, turbo VVT solenoid, etc.
    Also, what other size or sizes might I need before undertaking the job of replacing it all?
    Lengths needed of each roughly? Thanks.
  2. Re: 2001 Passat 1.9 TDi vacuum hose diameters and lengths
    Aug 2011
    Meath
    I think the vacuum hose is 3mil bore. you buy it by the yard/meter i suppose 3 or 4 would do it
  3. Re: 2001 Passat 1.9 TDi vacuum hose diameters and lengths
    Nov 2012
    Gwynedd, UK
    The stuff I've got did go on a connector with a bit of effort when I did a quick check earlier but visually the internal bore of the pipe is definitely smaller than the original stuff.
    Is the larger pipe 5mm inside diameter?
  4. Re: 2001 Passat 1.9 TDi vacuum hose diameters and lengths
    VAGMAN2 Guest
    It is 3/5mm internal dia. tubing.
  5. Re: 2001 Passat 1.9 TDi vacuum hose diameters and lengths
    Feb 2010
    luton uk
    the old hose would have taken the diameter of the fitting through heat and age but the small diameter pipe is definitely 3 mm and the larger pipe is 5 mm . think of them kids with huge holes in their ears they have to stretch their piercing to get the big ear decorations in but the ears won't shrink to fit a regular earring in
  6. Re: 2001 Passat 1.9 TDi vacuum hose diameters and lengths
    Nov 2012
    Gwynedd, UK
    Thanks for the info. Have got the 3mm pipe so will order some 5mm now I know it's correct.
  1. vacuum hose diagram for a TDI 130 AWX
    By vwnige in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-03-2012, 11:57 AM
  2. Replies: 6
    Last Post: 13-02-2012, 09:11 PM
  3. Vacuum hose
    By pete99 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-03-2011, 10:21 PM
  4. vacuum hose
    By heybertuk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-05-2009, 12:40 PM
  5. Vacuum Hose
    By mo_schino24 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 17-08-2007, 11:44 AM
