Thread: Engine pinking !!
Results 1 to 8 of 8
  1. Engine pinking !!
    Dec 2007
    Belfast
    Hi All.
    I am driving a 2001 1.6s 16v Golf 4 ( AZD ) with about 77,000mls.
    For quite a while now I am experiencing pinking from the engine which seems to be getting more noticable.
    It's at it's worst in 5th gear accelerating from about 40 or 50 mph.
    I am trying to fuel her with the highest grade of fuel that I can find, I think it is about 96ron.
    I would like to ask if there is anything I can do to minimise the problem or correct it.
    I have heard stories about tappets going, could this be a sign of this ?
    All feedback appreciated.
    Marko.
  2. Re: Engine pinking !!
    Aug 2011
    Meath
    Hi, Is it long since the plugs were changed, did you check them for carbon? Give her a VCDS scan the knock sensor may be on it's way out. She might also be running a little lkean but a scan first
  3. Re: Engine pinking !!
    Dec 2007
    Belfast
    Thanks for the quick reply.
    Plugs were done about 7000mls ago.didnt see them as a mechanic changed them.
    Whats the knock sensor ?
    What should I look out for on a scan ?
  4. Re: Engine pinking !!
    Aug 2011
    Meath
    The scan will show the fault codes stored in the car's ecu. With them you can start working out what the problem is. Pinking is usually caused by carbon build up on the plugs or inside the head its not common nowadays thanks to these KNOCK SENSOR 030905377C VW Golf Audi A4/TT Brand New | eBay
  5. Re: Engine pinking !!
    Dec 2007
    Belfast
    Can you enlighten me as to what a knock sensor does ?
    Also, do you reccomened I change my plugs ?
    Thanks.
  6. Re: Engine pinking !!
    Aug 2011
    Meath
    Plugs will be fine for a year or two mate. The knock sensor senses when the car is going to pink and adjusts the timing to compensate. The VCDS scan should come first it's cheaper than changing parts at random. There's a map on this site showing members with VCDS and where they are. there's should be someone near you
    VWAF User Location Map - VCDS - Google Maps
  7. Re: Engine pinking !!
    Dec 2007
    Belfast
    Is there a difference between VCDS and a bosch scanner or anyone who has diagnostics ?
    The nearest member with the VCDS is about an hour away. If there wasn't much difference it would save a journey.
    Marko.
  8. Re: Engine pinking !!
    Aug 2011
    Meath
    I haven't used a Bosch but have a look at this
    Ross-Tech: VCDS: DTC Comparison
    Break yourself in gently with one of these bad boys...
    http://www.gendan.co.uk/product_VAGUSB.html
  1. Please Help pinking cabby ADZ engine code
    By paul targett in forum Golf MK3 - 1993 - 1999
    Last Post: 09-11-2008, 06:29 PM
  2. Please Help ABK engine pinking / pre-ignition
    By audi80mk4 in forum 100 - 200 - Turbo - 100 S4
    Last Post: 22-09-2008, 07:30 PM
  3. Please Help ABK engine pinking / pre-ignition
    By audi80mk4 in forum 80 - 90
    Last Post: 30-08-2008, 02:23 PM
  4. Possible Pinking ???
    By mwshy in forum Golf MK4 - 1999 - 2004
    Last Post: 05-07-2008, 07:05 PM
  5. 3.2 Engine Pinking
    By Hillsy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-04-2008, 09:27 AM
