Thread: Black smoke after changing the synchronization angle in group 004, value 4
  1. Black smoke after changing the synchronization angle in group 004, value 4
    Aug 2012
    Sofia, BG
    My first post here, so I hope it's in the correct section. I have an Audi B6 and saw that the current value was 2.3. I wanted to change it,as I've read that the optimal value is 0.5. The problem is that now the car has a black smoke when started. I haven't driven it yet, to see how it goes.
    Is this normal, because the engine wasn't running properly before this change, or not? What else might be the problem?
    The nozzles' values seems to be ok on ch 13. The EGR seems to be fine too. It was cleaned two months ago.
    Thanks,
    Stan
  2. Re: Black smoke after changing the synchronization angle in group 004, value 4
    132 Post(s)
    1979 Post(s)
    Which year and engine code?
  3. Re: Black smoke after changing the synchronization angle in group 004, value 4
    Aug 2012
    Sofia, BG
    Apologies, it's 2003, AWX, 1.9
  4. Re: Black smoke after changing the synchronization angle in group 004, value 4
    132 Post(s)
    1979 Post(s)
    I don't have the original figure for that engine and I don't have a car in today with the same engine. What was the value in 004/4 when you first went into Basic Settings 04?
  5. Re: Black smoke after changing the synchronization angle in group 004, value 4
    Aug 2012
    Sofia, BG
    I should have said it was a mechanical work I unscrewed the three bolts on the camshaft wheel that holds the timing belt and turned it a bit. This changes the syncro angle.
  6. Re: Black smoke after changing the synchronization angle in group 004, value 4
    132 Post(s)
    1979 Post(s)
    Put it back where it was! The timing is set with pin and plate and no other method, as you have proven!!!
  1. Black smoke
    By Redzer in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-12-2009, 12:38 PM
  2. Manual Key Synchronization for 02 Passat
    By dixonmj in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-10-2009, 08:27 PM
  3. Black smoke
    By toneil461 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-06-2009, 04:44 PM
  4. Black smoke.
    By racer in forum TT - 8N Forum - 1998 - 2006
    Last Post: 28-07-2008, 03:18 PM
  5. black smoke
    By omair in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-09-2007, 05:54 PM
