Thread: Removing internal trim panel on Alhambra tailgate
  1. Removing internal trim panel on Alhambra tailgate
    Jun 2009
    Highbridge UK
    My rear screen washer has stopped working. I will need to remove the inner trim panel to see what's wrong. Has anyone done this before? I assume it is held on by the usual plastic clips that break when you try to remove them. Any tips would be appreciated before I have a go at removing it.
    Thank
  2. Re: Removing internal trim panel on Alhambra tailgate
    Before you pull the tailgate apart check the front passenger footwell, there is a pipe joint under the carpet which comes apart, also check the pipe in the convoluted trunking from the rear of the body to the tailgate - it can break here if tailgate opened in freezing weather - it's also not unheard of for the pipe to pop off the actual pump
  3. Re: Removing internal trim panel on Alhambra tailgate
    Jan 2013
    Northampton, UK
    wyndham, if once having done the check that matthewgdavis suggests (it's happened to me too), you find you do still need to get into the tailgate it's quite an easy job to do. There are no plastic clips that break, just metal spring clips.
    With the tailgate open, the window glass trim comes off first. The clips are around the outside of the tailgate. It's a little awkward up the sides as the direction of the clips requires a fair bit of distortion of the trim. They are sort of 90deg to the direction that the trim comes off. The top clips are much easier once the sides are unclipped.
    Then the main back panel cones off. Unclip the screw covers, remove the handle screws and handle, then the rest of the screws. They are all around the outside (none hidden anywhere else). Then unclip the trim using your fingers around the outside. Finally ease the trim downwards, gently leveraging the few clips out that run along below the window.
    At least this is how I do it on mine!
    Refitting is the opposite of removal but pay attention to the upper trim side clips that can get mangled and/or scratch the paintwork if you're not cautious.
    Dave
    Sent from my Nexus S using Tapatalk 2
  4. Re: Removing internal trim panel on Alhambra tailgate
    Jan 2013
    Northampton, UK
    Hi wyndham, I also found this post...
    Rear wiper not working how do you take the boot trim off as need to sort reversing lights too
  1. Trim panel for Avant tailgate
    By johnm in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 14-07-2012, 05:59 PM
  2. Removing tailgate trim
    By Mattwarner1979 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 18-07-2011, 07:06 PM
  3. removing internal panel on bootlid????
    By aaudi4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-02-2011, 03:26 PM
  4. Please Help Removing tailgate inner trim panel
    By Rozmic in forum Golf MK4 - 1999 - 2004
    Last Post: 17-01-2010, 06:08 PM
  5. Removing Tailgate Trim
    By ad1966 in forum Golf MK4 - 1999 - 2004
    Last Post: 29-01-2008, 09:08 PM
