Thread: Audi A4 Cabriolet '53' plate Servicing Items
  1. Audi A4 Cabriolet '53' plate Servicing Items
    Jul 2012
    Grantham
    Hi Folks,
    Am losing coolant and this might be the Oil Cooler?
    Garage have informed me it is leaking so seeing as not losing oil can only assume its leaking coolant
    In need of an oil change anyway so ideal time to do it. Also going to change spark plugs and air filter
    Looking around it appears there are several sized oil filters.......
    So before I start thought would ask the members on here what are the numbers of service items so ensure get correct ones
    Mister Auto currently have a 35% discount code so intent to order directly from them...unless members know somewhere better?
    Its a 53 plate B6 1.8T
    Thanks folks
  2. Re: Audi A4 Cabriolet '53' plate Servicing Items
    Pembrokeshire
    22 Post(s)
    if its your oil cooler leaking then the water will be going into the oil and that will turn a milky colour, so if its still like normal oil then its not the cooler leaking.
  3. Re: Audi A4 Cabriolet '53' plate Servicing Items
    Jul 2012
    Grantham
    Quote Originally Posted by zollaf View Post
    No sign of milky oil.........
    It is way overdue an oil change as the oil is very thin but still black so no water in it.....
    It is using about 1ltr of WATER every 400 miles.........small patches on drive.....
  4. Re: Audi A4 Cabriolet '53' plate Servicing Items
    Jan 2008
    Bournemouth
    my cab (bfb) engine was losing coolant from the temperature sensor housing, the gasket had gone. i had the temp sensor changed at the same time, cost around £180 (all in) from memory.
  5. Re: Audi A4 Cabriolet '53' plate Servicing Items
    Jul 2012
    Grantham
    Thanks for the reply.......
    Where is the aforementioned Temp Sensor Housing located then......is it a DIY job?
  6. Audi A4 Cabriolet '53' plate Servicing Items
    Jan 2008
    Bournemouth
    I would imagine some would consider it a DIY job, but from memory the parts only cost approx £30, so labour was the killer! I wouldn't want to advise where the housing is as I generally don't do stuff to my car unless I know what I'm doing. Too many times I've got half way through an attempted DIY task and realised I haven't got the right tools/parts, and then also have no car to go and buy them :/
  1. Are service items (apart from oil) same for longlife and time/distance servicing?
    By CharlesElliott in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-06-2012, 12:01 PM
  2. Question Audi A4 Carbon Items B6
    By A9X SJ in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-04-2010, 08:57 AM
  3. VW Polo '53' plate, ABS light come on.
    By dcfcshandy in forum Polo - Derby - Lupo - Fox
    Last Post: 18-03-2009, 06:59 PM
  4. Audi A4 DIY items
    By the_wave_rider in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-11-2008, 08:51 PM
  5. 53 plate cabriolet - roof stuck can't do the manual release
    By EddieTheAudi in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-05-2008, 07:55 PM
