Thread: B 5.5 Passat 130 TDI, losing power/not boosting properly
Results 1 to 10 of 29
  1. B 5.5 Passat 130 TDI, losing power/not boosting properly
    Nov 2012
    London UK
    I recently got my car back from the garage after having a new cat put on as there was a hole in the exhaust by the old one, when I got it back it was a completely different car, it now has hardly any power, the turbo does seem to come in at around 3500/4000 rpm sometimes at around town speeds, but on the motorway the car doesn't want to rev over 3000 rpm at all, the garage plugged it in to their diagnostic equipment and it came up with something to do with boost pressure or boost leak, I can't remember the exact fault code, I have checked all the pipes going to and from the turbo and all seem ok.
    Does anyone have any idea what this could be?, could the garage have broken something in the turbo while changing the cat?, as it is directly behind the turbo.
    I would really like to try and work out what exactly it could be, it isn't smoking and I can hear some noise from the turbo but only when revved very high and not the normal sound it makes.
    Any help would be much appreciated, lastly could anyone reccomend a decent garage around Surrey/SW London that would be good at finding this sort of fault because the one I used, while good for servicing etc don't really seem to know what it could be.
  2. Re: B 5.5 Passat 130 TDI, losing power/not boosting properly
    Aug 2011
    Meath
    You need to scan with VCDS and post the codes this could be a number of things not all of them expensive!
  3. Re: B 5.5 Passat 130 TDI, losing power/not boosting properly
    Pembrokeshire
    22 Post(s)
    as doc says, a vcds scan, but just check the thin vacuum pipe that goes to the turbo from the actuator and all other thin pipes in that area as well, just in case one has been dislodged whilst removing the exhaust.
  4. Re: B 5.5 Passat 130 TDI, losing power/not boosting properly
    Nov 2012
    London UK
    Thanks guys, I will get it plugged in and get back to you, bit of a strange question I guess but does anyone know if you can get the VW diagnostic software to run on a Mac?, if not I will have to borrow a friends laptop, I'm just going to buy a cable off Ebay.
  5. Re: B 5.5 Passat 130 TDI, losing power/not boosting properly
    Aug 2011
    Meath
    Buy your cable from somewhere reputable like http://www.gendan.co.uk/product_VAGUSB.html these are quite limited but a lot better than some ebay ones. VCDS doesn't work on a Mac as far as I know.
  6. Re: B 5.5 Passat 130 TDI, losing power/not boosting properly
    Nov 2012
    London UK
    Right, bit of an update now, I managed to install a Windows partition on my Mac and borrowed VCDS and the cable off a neighbour, the car is coming up with 4 fault codes:
    4 Faults Found
    17964 - Charge Pressure Control: Negative Deviation
    P1556 - 35-10 - - - Intermittent
    17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
    P1144 - 35-00 - -
    17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
    P1156 - 35-00 - -
    17569 - Manifold Temp Sensor (G72): Open or Short to Plus
    P1161 - 35-00 - -
    Readiness: 0 0 X X X
    I did try unplugging the MAF sensor first of all to see if this was the problem, same goes for whichever manifold sensor that goes to the back of the engine, I did reset the codes, took it for a drive and these 4 came straight back up, I'm assuming I'm going to need a new MAF and manifold sensor, don't have a clue about the manifold temp sensor or the carge pressure control though.
    Any idea where to start with this?.
  1. 130 tdi over boosting
    By shoolhouse in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-08-2012, 12:16 PM
  2. 07 a4 2.0 tdi 170 doesnt seem to be boosting properly?
    By 5m4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-04-2012, 12:03 AM
  3. Please Help VW Passat 1.9TDI 130 Losing Water
    By doigy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-04-2012, 05:47 PM
  4. Question audi s3 not boosting properly
    By nick maclean in forum New Member Introductions
    Last Post: 21-11-2009, 10:27 PM
  5. Please Help Passat 130 TDi intermittently losing boost
    By PeteK in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-10-2008, 09:03 PM
