Thread: 2004 1.9tdi rear brake disc/pad replacement
Results 1 to 10 of 13
  1. 2004 1.9tdi rear brake disc/pad replacement
    Mar 2009
    West Yorkshire
    Hi all, is this a dealer only job....seems my rear pads are well down and discs well grooved.
    i have replaced discs/pads on other cars(straight foreword with undo little hex bolt) but do these have bearings in them or not, can it be a DIY job.....
    any info helpfull as i would like to get then done before winter sets in propper...
    thanks
    kevin
    PS, it has a handbrake, not electric button/lever ???
  2. Re: 2004 1.9tdi rear brake disc/pad replacement
    Mar 2009
    Video link below, easier than me going through a long winded explanation. (probably a few more you can look at as well)
    2002 Volkswagen Passat,rear brake pads/rotor how to replace - YouTube
    I came in to this world with nothing and I've still got most of it left.
  3. Re: 2004 1.9tdi rear brake disc/pad replacement
    Mar 2009
    West Yorkshire
    ha haaa....i see, i think mine are a straight replacement without the bearing ???? so the video looks lik it...
    will manufacture a piston rewinder before hand......i have some threaded bar in the garage...
    kevin
  4. Re: 2004 1.9tdi rear brake disc/pad replacement
    london/ UK
    Buy the Laser tool from Halfords or ebay, much easier than messing about adapting stuff. I used long nose pliers and waterpump pliers but it goes much better with the right tool especially when calipers are seized... Also use decent axle stands when working under the car. You will need a thin 15mm open ended spanner and a 13mm ratchet spanner for the sliding bolts.
  5. Re: 2004 1.9tdi rear brake disc/pad replacement
    Aug 2011
    Meath
    The proper tool is cheap as chips i ruined a perfectly good circlip pliers trying that method.
  6. Re: 2004 1.9tdi rear brake disc/pad replacement
    Mar 2009
    West Yorkshire
  7. Re: 2004 1.9tdi rear brake disc/pad replacement
    Aug 2011
    Meath
    Car boot/market stall tools, spend a score buy no more!
  8. Re: 2004 1.9tdi rear brake disc/pad replacement
    Mar 2009
    West Yorkshire
    Hi, well all the good weekend stalls have been shut down near me so that line is a no go....
    is this the best purchase
    Volkswagen Passat Sharan Bora Eos Lupo Golf T4 T5 Brake Caliper Windback Tool | eBay
    i will be purchasing the brake discs/pads this week and might as well get a tool to do the job....
    kevin
  9. Re: 2004 1.9tdi rear brake disc/pad replacement
    Aug 2011
    Meath
    Sorry mate I mean US pro are the sort of tools that are sold at car boots markets etc.
    Halfords | Laser Brake Caliper Rewind Tool
  10. Re: 2004 1.9tdi rear brake disc/pad replacement
    Norfolk
    Quote Originally Posted by unclespevie View Post
    kevin
    That will be fine.
  1. Brake Disc / Pad recommend
    By fisgard792 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-08-2011, 12:08 AM
  2. "How To" Front brake pad/disc replacement
    By bora(ing) nick in forum Volkswagen
    Last Post: 24-06-2011, 12:05 PM
  3. ABS & ESP Lights On After Pad/Disc Replacement
    By OSB in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-03-2011, 03:06 PM
  4. Does anyone have brake disc/pad recommendations?
    By adowds in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 04-11-2008, 10:20 PM
  5. rear brake pad replacement
    By 1100xx in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-04-2008, 09:19 PM
