Thread: Boost Sensor location - 3.0 TDI BKN
  1. Boost Sensor location - 3.0 TDI BKN
    Aug 2012
    Sleaford Lincolnshire
    Hi all,
    Could someone help me locate the boost sensor on my Audi A4 3.0 TDI Quattro? It has the BKN 204bhp engine (55 plate).
    i think I've found 2 possible culprits, both on near side (passenger side).
    One is on a metal box with Siemens VDO written on it, attached to a metal inlet pipe, BEHIND the headlight.
    The other is UNDER the headlight, screwed into a box or pipe.
    Both have same 4 pin connector, which is rectangular but with one of the short ends circular (like a church window).
    Any help would be appreciated.
  2. Re: Boost Sensor location - 3.0 TDI BKN
    131 Post(s)
    1976 Post(s)
    The Charge pressure sender G31 is on the left intercooler, accessible once the front bumper and left headlight have been removed.
  3. Re: Boost Sensor location - 3.0 TDI BKN
    Aug 2012
    Thanks for the reply.
    I don't need to remove it, I am plugging in a DTUK CRD-T which uses this sensor. This is the photo I took of the sensor under the near side head light -
    http://img.photobucket.com/albums/v6...B1D014FEA1.jpg
    Does it look like the boost sensor?
    Thank you.
  1. Please Help loss of boost, map sensor location
    By andyuk25 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-05-2012, 12:14 AM
  2. Question Location of the IAT (G42) and Boost Sensor (G31) Sensor
    By Poenie in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-04-2010, 12:17 AM
  3. Please Help Location of Coolant Sensor - 2004 1.9 TDI 130
    By redhotorange in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-06-2008, 10:39 PM
  4. location of temp sensor on 115PD TDI Passat.
    By printman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-07-2007, 05:56 PM
  5. Golf IV TDI Map sensor location
    By smoker in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-03-2007, 06:22 PM
