Thread: Turbo pressure sensor fault
Results 11 to 20 of 40
  1. Re: Turbo pressure sensor fault
    Nov 2012
    Bolton
    Cheers for that everyone, now just need to find a garage as not sure about the one I went to. I know this may be a dumb question but would the work be more complicated due to it being 4 wheel drive?
  2. Re: Turbo pressure sensor fault
    Pembrokeshire
    22 Post(s)
    no, the turbo is the same regardless.
  3. Re: Turbo pressure sensor fault
    131 Post(s)
    1973 Post(s)
    Sorry Zolly but I beg to differ because getting the turbo off on a Golf 5 4 Motion is a hell of a lot more difficult than on a 2wd. We have just done one on a Passat 3C 4 Motion this morning and it doubles the time the job takes.
  4. Re: Turbo pressure sensor fault
    Pembrokeshire
    22 Post(s)
    i bow to your superior knowledge
    no i do, seriously.
    so long since i have seen one tbh, and none of the peasants around here can afford anything good like that.
  5. Re: Turbo pressure sensor fault
    Nov 2012
    Bolton
    Sounds like I'll be on bread and water to sort it out! Only had it a month, gutted
  6. Re: Turbo pressure sensor fault
    131 Post(s)
    1973 Post(s)
    I would lay good money on the previous owner (not necessarily the dealer if you bought it off one) being fully aware of the problem and that is why they unloaded the car onto someone else.
    0 2 0
  7. Re: Turbo pressure sensor fault
    #17
    Nov 2012
    Bolton
    Yeah could be the case, thought with it only having one owner from new and 87K on the clock it was a good buy. Just my luck to finally have the car I've lusted over for so long to cause me a headache so soon. Starting to miss my trusty old volvo!
  8. Re: Turbo pressure sensor fault
    #18
    Pembrokeshire
    22 Post(s)
    it still is a good deal, its just got a small problem that needs sorting out and it could be a lot worse. how long have you owned it then, sounds like not very long and the dealer may be able to get it fixed for you under their warranty. don't give up on it, loads better than any volvo, imho.
  9. Re: Turbo pressure sensor fault
    #19
    Nov 2012
    Bolton
    Got it in Sept. Got a 3month warranty with it thro warranty wise, but although turbo is covered when you read the small print it appears parts that fail due to carbon built up are excluded so that's a bit of a worry
  10. Re: Turbo pressure sensor fault
    #20
    Pembrokeshire
    22 Post(s)
    what sort of establishmnet did you buy it from, small backstreet dealer, main dealer etc..
    technically, a used car has a 6 month warranty anyway from the trader that sold it. they can't sell you a duff motor and then wash their hands of it. check out the sales of goods act for more info about it, but in your shoes i would be talking to the seller and if they didn't co operate i would get it done and see them in the small claims court to re-imburse me my expenses.
  1. Fault 00575 - Manifold Pressure Sensor
    By BadgerBoy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-09-2014, 07:12 AM
  2. Please Help Fault - 00810 - Sensor 1/2 for Brake Pressure
    By butthefuko in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-09-2012, 04:06 PM
  3. A3 01435 - Brake Pressure Sensor 1 (G201) Fault and others
    By grimzz in forum VCDS - Help Requests
    Last Post: 30-10-2011, 05:07 PM
  4. Brake pressure sensor fault
    By if11677 in forum Golf MK5 - 2004 - 2009
    Last Post: 06-11-2010, 12:49 PM
  5. A/C high pressure sensor fault
    By badass76 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-01-2010, 06:13 PM
