Thread: '91 passat 1.9td ECU
  1. '91 passat 1.9td ECU
    Nov 2012
    France
    I have just been given this car which had the starter motor removed. I replaced it with a good one and now I cannot get it to start. The motor turns but all I get is smoke from the exhaust. It has been standing for a couple of years.
    Is there an ecu on this model? and where is it located?
  2. Re: '91 passat 1.9td ECU
    Aug 2011
    Meath
    you need to replace the fuel filter air filter and get some clean fuel. Test the glow plugs by removing them and see if they heat up properly. If not replace them. Don't be tempted to use easystart. There's no ECU is it turbodiesel?
  3. Re: '91 passat 1.9td ECU
    Nov 2012
    France
    Thanks for the reply. It is a turbo diesel. Is there an electric fuel pump,there is no sound of one? I will test the resistance of the glow plugs.
  4. Re: '91 passat 1.9td ECU
    Aug 2011
    Meath
    no electric pump it sucks up the diesel from the tank. you could try to start it with a clean plastic bottle of diesel and a piece of tubing
  5. Re: '91 passat 1.9td ECU
    Nov 2012
    France
    It runs now. I hot wired the glow plugs and bled the injectors. The glow plugs can now be used normally. Thanks for your patience.
  6. Re: '91 passat 1.9td ECU
    Aug 2011
    Meath
    Resul!, if you're going to keep it treat it to a gallon of oil
  1. Passat 04 1.9td
    By Taffy 04 in forum Vehicle Security - Retrofit / aftermarket alarms & immobilisers
    Last Post: 12-09-2012, 08:55 AM
  2. ecu power upgrade/ swap for passat possible???
    By 930JON in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-10-2010, 02:12 AM
  3. timing belt 1995 1.9td umwelt passat
    By dazzert66 in forum Early Passat Forum - Pre 97
    Last Post: 15-09-2009, 08:14 PM
  4. Please Help passat 18t gearbox ecu problem help
    By doovie911 in forum New Member Introductions
    Last Post: 08-03-2009, 09:45 AM
  5. Seeking Maintenance Advice for 95 Passat 1.9TD Umwelt
    By bmess1 in forum Passat - Archive Topics
    Last Post: 27-03-2007, 12:54 PM
