Thread: AC Problem (bora uk)
  1. Question AC Problem (bora uk)
    Aug 2007
    The AC on my Jetta stopped cooling after being parked. The system was working correctly, I parked vechicle for 5 min. When started again the AC does not cool. Fan works fine, I checked fuse, seems to be OK. Is there a relay or anoter fuse that could keep the compressor from cooling?
  2. Re: AC Problem
    Jul 2007
    Hello There
    What age is your Jetta/one minute it worked and then not? A quick pressure check will tell whats happening because if pressure is lowish compressor willl not cut in via pressure switch
    Good Luck
  3. Re: AC Problem
    Aug 2007
    My Jetta is a 2001 modle with 178K, thanks I will try the pressure, by the way it was 106 today.
  4. Re: AC Problem
    Aug 2007
    Northern Ireland
    IIRC the electro-magnetic compressor clutches can give some trouble, maybe worth checking if it is kicking in properly. If it's not, then check that power is getting as far as the clutch pack and make your decisions from there.
    Pete
  5. Re: AC Problem
    Aug 2007
    Thanks Pete, that is something else to check. I think it is an electrical problem so it may take a while.
  6. Lightbulb Re: AC Problem
    Aug 2007
    OK I gave up and wnet to the dealer, I know not good! Anyway the problem was the AC Control Module and the Large Radiatior Fan and Control Module. Replace ALL the system is working fine, my pockets are empty.
    Thanks for all the inpurt, hope no ome else has this problem.
  7. Re: AC Problem
    Dec 2008
    Wher is the AC control module situated?
  1. Bora indicator problem
    By xerian in forum Bora - 1998 - 2005
    Last Post: 20-06-2008, 05:39 PM
  2. bora problem
    By kirt48 in forum Bora - 1998 - 2005
    Last Post: 11-05-2008, 06:16 PM
  3. Steering Problem Bora 2.0
    By super_polo_mint in forum Bora - 1998 - 2005
    Last Post: 22-03-2008, 12:29 PM
  4. Help on Bora collant Problem
    By 0c2pus in forum Bora - 1998 - 2005
    Last Post: 01-08-2007, 09:15 AM
  5. Bora instrument problem
    By Gward in forum Bora - 1998 - 2005
    Last Post: 27-04-2007, 04:56 PM
