Thread: Leon TDi cold start problem
Results 1 to 10 of 11
  1. Leon TDi cold start problem
    Hi, I wondered if anyone can shed any light on a problem with my Leon TDi (150). I’ve only had it a couple of weeks and all appears well apart from there appears to be an issue with cold starting.
    When it’s first started, it just seems to struggle to get going, if I give it half throttle, it sometimes catches a bit better but usually it just ‘chugs’ for a bit and then amid a cloud of diesel smoke improves bit by bit until it runs properly (this takes about 10 to 15 seconds).
    I haven’t taken it anywhere as yet but just wondered if this was a common fault/problem that was an easy fix such as replace glow plugs etc.
  2. Leon TDi cold start problem
    46 Post(s)
    Fuel filter?
  3. Re: Leon TDi cold start problem
    Cheers, it's a starting point.
  4. Re: Leon TDi cold start problem
    Aug 2011
    Meath
    You'd really need to do a scan with VCDS it could be a sensor, glow plugs etc
  5. Re: Leon TDi cold start problem
  6. Re: Leon TDi cold start problem
    Feb 2013
    Cambridgeshire uk
    R u sure u r pre heating the glow plugs enough? When it is really cold i will cycle my ignition a couple of times, give it a couple of 10 second bursts on the ignition before starting it.
    If its really cold then the temperature won't build enough under compression to ignite, and therefore, start.
    Give that a try before changing anything and spending money on it mate as if its just in cold conditions it will not be anything fuel related. At the most it would be glow plugs
    Let me know how u get on
  7. Re: Leon TDi cold start problem
    Thanks, you would have thought by the end of Feb we wouldn't be having anymore cold mornings. I'll give your suggestion a try and see what happens. A mate has just bought an A4 tdi 130 and has a similar problem. Apparently it's common with this type of injector. Probably another case of 'you get that with that model!'
  8. Re: Leon TDi cold start problem
    Feb 2013
    Cambridgeshire uk
    It's just diesel mate. I have a pd170 and mine really struggled a couple of times last month.
    Where as petrol ignites with a spark, diesel relies on heat caused by compression, which will then ignite itself if it reaches the desired heat. Obviously if the cylinder is cold then it might not reach the temperature needed for combustion.
    Hope this helps and hope I'm not teaching u to suck eggs lol. Sorry if I am
  9. Re: Leon TDi cold start problem
    Benzy,
    Thanks for this. Don't worry, no offence taken. Any response is always helpfull even if it only reaffirms what you already think. As temperatures have soared to the heady hights of 3degrees, the problem has sort of gone away.
  10. Re: Leon TDi cold start problem
    Feb 2013
    Cambridgeshire uk
    Haha ye, this lovely hot weather, next problem will be the air con needing re gassing haha
  1. mk4 tdi cold start judder problem
    By rookie in forum Golf MK4 - 1999 - 2004
    Last Post: 04-12-2013, 07:33 PM
  2. a4 tdi cold start problem
    By stewvr6 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-04-2009, 10:18 AM
  3. TDI cold start problem!!
    By del_boy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-01-2009, 12:44 PM
  4. TDI cold start problem
    By eddy_p in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-08-2008, 11:25 AM
  5. Golf mk3 CL TDi `95 cold start problem
    By saxman in forum Golf MK3 - 1993 - 1999
    Last Post: 16-12-2007, 03:38 PM
