Thread: Compression pressures
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Compression pressures
    Oct 2012
    Norfolk
    I did lap the valves in as they was quite a bit of carbon on the valves and piston tops. Think I'll get the head checked first before I do the rings as if its cracked will be cheaper to scrap the car.
  2. Re: Compression pressures
    Oct 2012
    Norfolk
    Started the strip down today and when i removed the exhaust manifold. No 1 exhaust port was running with oil. this must mean either I,ve botched up the stem seal.(dont think so as it was smoking before), valve guide or head cracked.
    thanks for all you help chaps.
    Anyone got a head for an aee engine
    My cars Golf MkIII 1.6 cl.........RobinHood Lightweight 1.8 Zetec..............Vauxhall Astra G 1.6
  3. Re: Compression pressures
    Aug 2011
    Meath
    Take the valve out first it might just be the seal, we all make mistakes that's why they put erasers on pencils. If it's toast there's loads of VAG breakers There's one on fleabay for 50 quid from a guy in Northern Ireland that breaks VAG
    Audi A3 VW BORA GOLF MK4 1.6 Cylinder Head & Cam Shaft 06B103373A 06B 103 373 A | eBay
  4. Re: Compression pressures
    Oct 2012
    Norfolk
    Thanks Doctle Odd. Not sure thats the correct head for mine. the head on my car casting no is 032 103 373 k
    would this one fit as the end letters different and the cc
    VW GOLF MK3 POLO 1.4 CYLINDER HEAD 032 103 373 G 032103373G | eBay
  5. Re: Compression pressures
    Aug 2011
    Meath
    To be honest mate I don't know if that head would fit. I sent the link because you said you might scrap it and I wanted to show you that a replacement head would make it live again. I'd check yell for a local specialist breaker they would have the right one in stock. Lot of work and hassle with return postage etc if you buy a wrong/dodgy head off flea bay. Check your local paper too you might pick up a crashed one for the price of a head
  6. Re: Compression pressures
    Oct 2012
    Norfolk
    Update...
    Replaced head still smoked
    have now replaced piston rings and just started it. seems to have worked
    Did notice the thermostat had broken the location pit the nipple pushes against meaning it would never open, maybe causing the problem in the first place. Will find out Saturday when I can give it a good run.
  1. Please Help no compression
    By peter cutmore in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-03-2012, 01:48 AM
  2. No compression in cylinder 2...WHY????
    By andy___b in forum Golf MK4 - 1999 - 2004
    Last Post: 21-12-2011, 05:13 PM
  3. Question Compression Test
    By nathancrowster in forum Golf MK4 - 1999 - 2004
    Last Post: 22-08-2009, 06:46 PM
  4. no compression
    By steve12 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-04-2009, 07:47 PM
  5. compression test
    By mickmills in forum The Commercial Range
    Last Post: 30-06-2008, 08:24 PM
