Thread: Compression pressures
Results 1 to 10 of 16
  1. Compression pressures
    Oct 2012
    Norfolk
    After asking about engine swap. decided to change rings. just done a compression test and all cylinders are showing nearly 200psi. lowest was 185. this doesn't seem low to me and they all got to that pressure straight away. trying to cure the smoking.
    just a thought the would the cat store oil that would cause the blue smoke? might remove it tommorow and see.
  2. Re: Compression pressures
    Pembrokeshire
    22 Post(s)
    pressures sound good to me.
    when does it smoke, remind me. all the time, under power, over run ?
    not got a blocked breather has it.
  3. Re: Compression pressures
    Oct 2012
    Norfolk
    slight smoke on idle, lots when accelerating.replaced head gasket valve stem seals ect. removed the breather from the engine and cleared it right out was full of mayo. breather still producing a little oil misting. scratching my head on the readings. used 2 testers with same result|?
  4. Re: Compression pressures
    Pembrokeshire
    22 Post(s)
    and its blue smoke that smells of burning oil ?
    is there any pressure if you remove the oil filler cap while shes running ?
  5. Re: Compression pressures
    Oct 2012
    Norfolk
    blue smoke does smell of oil and no i hadn't checked to see if there is any pressure with the cap removed. will check tomorrow.
    what does it mean if there is?
  6. Re: Compression pressures
    Aug 2011
    Meath
    Did you change the rings yet? were the pistons tight, bores scratched?
  7. Re: Compression pressures
    Oct 2012
    Norfolk
    not changed the rings yet. thought I'd check witch cylinder was the problem.Even removed plugs 1 at a time to see if it smoked less. no difference i could see.
    When I had the head off the piston bores looked fine with no lip at the top but i could move the pistons back & forth a few mil
  8. Re: Compression pressures
    Aug 2011
    Meath
    What year is it? Is there any slap? A set of rings even a set of oil rings might help. If there was mayo there may have been a blown head gasket so maybe get the head checked ?
  9. Re: Compression pressures
    Oct 2012
    Norfolk
    98 golf mk3 1.6 with the aee engine. So you think the top compression rings are probable ok with the oil ring/scaper giving up the ghost.Looks like Im going for the complete rebuild then.My first time
  10. Re: Compression pressures
    Aug 2011
    Meath
    You can change all the rings and shells when you have the head off for testing! The oil ring comment was a bit throwaway sorry, rings aren't that expensive. Did you regrind the valves when you done the seals?
  1. Please Help no compression
    By peter cutmore in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-03-2012, 01:48 AM
  2. No compression in cylinder 2...WHY????
    By andy___b in forum Golf MK4 - 1999 - 2004
    Last Post: 21-12-2011, 05:13 PM
  3. Question Compression Test
    By nathancrowster in forum Golf MK4 - 1999 - 2004
    Last Post: 22-08-2009, 06:46 PM
  4. no compression
    By steve12 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-04-2009, 07:47 PM
  5. compression test
    By mickmills in forum The Commercial Range
    Last Post: 30-06-2008, 08:24 PM
