Thread: B6 passat tdi glow plug light flashing
  1. B6 passat tdi glow plug light flashing
    Oct 2011
    scotland
    Have a small issue with my glow plug light flashing prior to starting, after removing key a couple of times
    its ok and starts, could this be needing glow plugs? have had new injectors and turbo fitted within the last year
    any ideas?
    Thanks in advance
  2. Re: B6 passat tdi glow plug light flashing
    Southern County Softy
    20 Post(s)
    Scan for faults.
    If you don't have VCDS
    Look in the vagcom section for a member in your area.
    ....If only I was as smart as this bloody phone
    A4 2.5 tdi QS (mapped)
  3. Re: B6 passat tdi glow plug light flashing
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    If the glow plug light flashes at start up I would also expect a message e.g. "Engine Fault" on the Multifunctional Display? As Kite states the best way is for a VCDS (VAG COM) fault code scan which will narrow down where the fault lies. Note: 170 HP Tdi cars sometimes need the 7v glow plugs not the 4.4v versions. Make sure this is checked out before replacement.
    Mad Mitch
  4. Re: B6 passat tdi glow plug light flashing
    Jun 2014
    United Kingdom
    Hi did you find out what the problem was? iv just got my first vw passat and have the same problem. If i leave the car for any time at all the glow light flashes before i start and i have to take the key out 2 or more times then it will start. if i try to start it before it will start then die then just crank over.
    Quote Originally Posted by ctm73 View Post
    any ideas?
    Thanks in advance
  1. Please Help ECS light permanently on and flashing glow-plug lamp on 1.9 TDI
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-01-2013, 01:45 PM
  2. Passat 1.9 tdi AFN. Flashing glow plug warning light.
    By stephenlaurie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-04-2012, 09:29 PM
  3. Please Help, Glow Plug Flashing (2005 VW 2.0 TDI Passat)
    By scottjenkins in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-01-2011, 11:48 AM
  4. Question a4 tdi in limp mode and glow plug light flashing
    By iwa.r8 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-02-2010, 12:33 AM
  5. Please Help 1997 1.9 tdi vw sharan glow plug light on (not flashing) then won't start
    By jules n in forum Touran - Sharan - Caravelle
    Last Post: 12-09-2008, 09:53 PM
