Thread: over cooling
  1. over cooling
    Nov 2012
    tring
    hi
    got a bora with an overcooling problem.
    when im driving it, it will bearly move off the cold position,but if i let it idle, with 2 mins it will go to normal position, but as soon as you get going again it will fall back down with in 1 min.
    so im guessing the air flow throu the rad is overcooling.
    could it be the thermostat knackered or something else? sensor.
    getting very little heat from the blower.
    any ideas?
  2. Re: over cooling
    Aug 2011
    Meath
    Sounds like a thermostat mate, you should give it a scan with VCDS first of all
  3. Re: over cooling
    Sep 2009
    Cheltenham England
    I also have a Bora(ing) with almost the same problem. Not much heat from the heater and takes 10+ miles to get to temp. If I stop in traffic it gets up to temperature set off and it drops again. I did check the termostat (it was OK), then replaced it as it was only cheap. Still the same.
    I then bought VCDS tool and lo and behold the G2 engine management sensor is FUBAR (£22 Eurocarparts), googled and it appears a common fault. Also fan switch faulty also (£22 Eurocarparts). I am due to pick them up and replace in the next few days.
  4. Re: over cooling
    Jun 2009
    Had the same sort of problem with mine, it was the temp. sensor that was dodgy and also caused poor running. Swapped it twice, never pays to get a cheapo. GSF had one identical to original and was about £15.00.
    Don't believe the gauge, its the temp. sensor telling tales.
  1. Question Cooling system
    By herbie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-02-2011, 07:49 PM
  2. a/c not cooling
    By shazoo in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 24-09-2010, 12:17 PM
  3. Question Over cooling
    By PAPPA in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-10-2009, 11:17 AM
  4. Please Help A3 Cooling fans always on
    By MAFED in forum Audi A3 - Archive Topics
    Last Post: 06-03-2009, 11:33 PM
  5. cooling fan
    By mike d in forum The Commercial Range
    Last Post: 02-07-2007, 11:47 AM
