Thread: Clutch pedal started clicking this morning?
  1. Clutch pedal started clicking this morning?
    Aug 2012
    My clutch pedal started clicking this morning car is a 2008 mk5 golf tdi and the click happens at the very top of the pedal when you first start to push on the pedal you can feel it had a quick look under there but can see much any ideas?
  2. Re: Clutch pedal started clicking this morning?
    131 Post(s)
    1976 Post(s)
    Sounds like the clutch master cylinder is failing.
  3. Re: Clutch pedal started clicking this morning?
    Jun 2012
    Nottingham
    I wouldn't doubt Crasher's response as he really knows his stuff but I know Mk4 Golfs sometimes have a problem with the bracket on the clutch pedal that the actuator rod goes into; the weld breaking so the actuator rod end can move around and eventually come out or push through completely. Not sure if the Mk5 is the same but might be worth a closer look because if the bracket weld is failing, you may well get a 'clicking' sensation.
  4. Re: Clutch pedal started clicking this morning?
    Aug 2012
    thanks for the replys, i have noticed if i push the pedal to the left slightly while pushing it down it doesnt click and also if i push it gently it doesnt click
  5. Re: Clutch pedal started clicking this morning?
    131 Post(s)
    1976 Post(s)
    Just doing an S5 with a similar problem, it is also preventing the starter lockout from functioning correctly. Evil job to change.
  6. Re: Clutch pedal started clicking this morning?
    Aug 2012
    Quote Originally Posted by leeanderin View Post
    Seems to be affected by temperature,its worse when cold in the morning and seems to get better when temperature gets warmer...
  1. Clutch pedal needing adjusted or Clutch on way out?
    By rossvwp4m in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-04-2010, 05:57 PM
  2. Clutch Pedal making "Clicking" sound when pressed down
    By Eire12 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-05-2009, 04:26 PM
  3. Clutch pedal Help please
    By Gomar in forum Golf MK4 - 1999 - 2004
    Last Post: 17-01-2009, 02:00 PM
  4. clutch pedal
    By frank99jc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-07-2008, 09:47 AM
  5. CLutch pedal
    By sonic in forum Polo - Derby - Lupo - Fox
    Last Post: 11-03-2008, 08:26 AM
