Thread: Glow plug and relay fault finding
  1. Glow plug and relay fault finding
    Jan 2012
    Sandhurst
    2002 A6 1.9tdi - don't know the engine code but I think it's AWX, the sticker in the boot is missing.
    It's been hard starting recently so I have been taking a look at the glow plugs. It seems they aren't getting any power. I've found the relay I think, next to the ECU top right of engine bay in a box. I've put a meter on it and when I turn the ignition on the red/ yellow wire that goes to 87a goes live but nothing at the plugs.
    Any ideas? Is there a post relay fuse?
    Also found a "tuning" box on the car. Took it apart and it's a 150omh resistor in a box, what's that all about?
    Adam
  2. Re: Glow plug and relay fault finding
    Jul 2011
    Norway
    Ebay "tuning box" serial connected to the MAF, fools the ECU to believe more air is beeing drawn in than it actually is.
    Most expensive resistor you can possibly buy
  3. Re: Glow plug and relay fault finding
    Jan 2012
    Sandhurst
    OK I've been digging around a bit more.
    I think I didn't make a proper connection when I was measuring voltage at the glow plugs. I unplugged the coolant sensor so the glow plugs stayed on for as long as possible. I removed a plug and made an earth straight to the battery with a cable and with ignition on the plug glowed red after a few seconds.
    So what's next
  1. glow plug relay
    By andwat in forum Golf MK5 - 2004 - 2009
    Last Post: 17-01-2012, 12:31 AM
  2. Please Help Where is the glow plug relay???
    By pryrates in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-01-2010, 06:28 PM
  3. Question Glow Plug Relay
    By BadgerTF in forum Leon
    Last Post: 02-03-2009, 12:40 AM
  4. glow plug relay
    By A4-v6 in forum Chat - Anything with wheels
    Last Post: 28-01-2009, 12:34 PM
  5. Glow Plug relay
    By Skelts in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-06-2008, 07:16 PM
