Thread: P3348!!
Page 1 of 3 123 LastLast
Results 1 to 10 of 28
  1. P3348!!
    Sep 2012
    Berkshire
    So not long after I bought my car from stratstone the EML came on, the stratstone I bought it from are a jag specialist but had a universal OBD2 port reader and it bought this fault up:
    19804/P3348/013128 - Ross-Tech Wiki
    They told me nothing to worry about and that it says to clear it intermittent so keep driving it...MY ****!
    I asked for the code so I could get a better understanding, when I next spoke with them I told them everything off the ross tech site - they said we need a second opinion from Audi which they got, and it was everything I said to them - lol
    Its now getting a new turbo, will get it back next week
    My grammar is probably rubbish because Im a bit livid writing this and the car has been with Stratstone/Audi for over a week and i really miss it
    Patience is a virtue
  2. Re: P3348!!
    Aug 2011
    Meath
    So why is the turbo being replaced?
  3. Re: P3348!!
    Sep 2012
    Berkshire
    Theres an actuator/solenoid on the turbo thats gone faulty and/or the turbo veins are blocking, this is throwing up the fault, and the only resolution is a turbo unit change
  4. Re: P3348!!
    Aug 2011
    Meath
    solenoid is replaceable vanes can be cleaned, I think you should get a second opinion
  5. Re: P3348!!
    Pembrokeshire
    22 Post(s)
    that code clearly says electrical fault. there is nothing electrical on a turbo. ???
    what engine code do you have ? or type of engine if you can't get the engine type code.
    very strange i think.
  6. Re: P3348!!
    Aug 2011
    Meath
    I am guessing the boost control solenoid. imo you really need VCDS for VAg cars obd scanners even big brand names still miss stuff
    Ross-Tech: VCDS: DTC Comparison
  7. Re: P3348!!
    Sep 2012
    Berkshire
    Yes, Audi has confirmed it, first Stratstone got that code then they sent it to Audi for a second opinion and the same code came up - they are changing the turbo under warranty so i cant complain
  8. Re: P3348!!
    135 Post(s)
    2036 Post(s)
    They may be fitting a new turbo but it won't cure it. I have one of the same cars in today and see a lot of 2L 4F's with this code and it is simply a broken wire to the solenoid as the wiring was designed too short and thin.
  9. Re: P3348!!
    Sep 2012
    Berkshire
    How would you know it wont cure it? and How would you know they havent checked the wiring/fuses etc, i requested them to make certain checks after reading up on similar issues on here and the ross tech page which they have confirmed they checked
  10. Re: P3348!!
    Sep 2008
    mostly in the garage
    who cares, get the nice shiny turbo anyway , they can fix wiring after if it turns out it's necessary!
