Thread: equivilant engines for swap
Results 1 to 10 of 11
  1. equivilant engines for swap
    Oct 2012
    Norfolk
    I have a Golf 1.6 cl and the rings/pistons have had it. The engine is an AEE which i'm having problems finding. Are there any other engines that would do the trick and be a straight swap?
  2. Re: equivilant engines for swap
    Pembrokeshire
    22 Post(s)
    welcome to the forum. have you had the head off, if so what are the bore like ? if they are any good then new rings are cheap and easy to fit once the sump is off. the bores can be honed back to life as long as they are not too far gone.
  3. Re: equivilant engines for swap
    Oct 2012
    Norfolk
    Hi Zollaf
    Yes I've completely rebuilt the head and replaced the valve stem seals as i originally thought this was the problem with a blowing head gasket. Should have done a leak down test first Bores look good but could move the pistons around quite a bit. Afraid crankshaft and pistons are beyond my expertise and workshop. Replacing the engine seems easiest to me.
  4. Re: equivilant engines for swap
    Pembrokeshire
    22 Post(s)
    oh come on, if you can rebuild a head then you can change the piston rings. , but, pistons should move around in the bores a bit. right, any scores in the bores and any ridge at the top you can feel. if alls good, you drop the sump off, undo the big end bolts and use a wood drift to knock the pistons up and out. when they are all done, run a hone tool in a drill up and down the bores to remove glazing. its all on youtube how to do it. cover the crank journals with rag first. then remove the rings from the old pistons and fit new, following the fitting diagram and using a pair of piston ring pliers. then a ring compressor to fit the pistons back, new big end shells in, new bolts torqued up and jobs a goodun. its no harder than doing a head and a used engine might be worse than you already have.
  5. Re: equivilant engines for swap
    Oct 2012
    Norfolk
    my problem doing the bottom end is getting the right clearances for the rings and big end shells. measuring is not my greatest asset (prefer best estimate and large hammer). Will check the youtube to see whats needed. Thanks for your advice.
  6. Re: equivilant engines for swap
    Pembrokeshire
    22 Post(s)
    the big end shells, they are stamped with their size anyway, but will more than likely just be standard, so just replace with whats in their already. the rings should also fit straight out the box, but all you need to do is fit them to the bore and measure the gap at the ends with a feeler gauge and make sure its within spec. if they are tight, just grind a bit off, but you probably won't need to, just fit and forget. the pleasure you will get doing it will outweigh any thoughts you have of why you can't do it.
  7. Re: equivilant engines for swap
    Aug 2011
    Meath
    Of course you could do a 1.8T conversion...
  8. Re: equivilant engines for swap
    Oct 2012
    Norfolk
    Ref the rings would I need to get oversize or are the originals prone to wearing down? Which wears first Block or rings
  9. Re: equivilant engines for swap
    Aug 2011
    Meath
    The rings usually wear first so unless it was rebored standard rings and standard shells. It will really tighten up the engine.
  10. Re: equivilant engines for swap
    Oct 2012
    Norfolk
    Quote Originally Posted by paulkennedy View Post
    Which engine code would be straight swap?
  1. is engines the same?
    By sheltieman in forum Chat - Anything with wheels
    Last Post: 22-11-2009, 12:19 AM
  2. Please Help Passat Headlight swap, is it posible to swap early / late over?
    By scotlandstu in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-05-2009, 11:26 AM
  3. Various 1.8T and 2.0 engines
    By dannyboy32 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-02-2008, 02:02 PM
  4. PD engines
    By a41.9tdi in forum Chat - Anything with wheels
    Last Post: 11-10-2007, 07:46 PM
