Thread: Dual Mass Flywheel & Clutch mystery
  1. Dual Mass Flywheel & Clutch mystery
    Apr 2009
    After reading all the symptoms relating to the DMFW & Clutch, and on the advice of a local garage, we were convinced that the problem was the DMFW. So i paid for a new DMFW & clutch to be fitted, only to discover that the problem is still there!
    When i contacted the garage he now says it may the drive shaft or the gearbox.
    Before i go down another expensive route, can someone please advise what else the symptoms of a Flywheel juddering may be? It usually happens in 2nd or 3rd gear when gently driving out of a roundabout for instance. Accelerating removes the juddering from that area.
    Any advice would be most welcome.
    Its done 70k and is a 2.0TDI
    many thanks
  2. Re: Dual Mass Flywheel & Clutch mystery
    Colchester,Essex
    what is 1st gear pull off like?
  3. Re: Dual Mass Flywheel & Clutch mystery
    Apr 2009
    Quote Originally Posted by turpal View Post
    1st gear is absoloutely no problem as far as im aware. As i said, its always noticeable in 2nd, but more so in 3rd gear
  4. Re: Dual Mass Flywheel & Clutch mystery
    Colchester,Essex
    Unless I feel myself can`t comment,sorry.If it was in 1st aswell than a new dmf I`d say as some newones come faulty too.
  5. Re: Dual Mass Flywheel & Clutch mystery
    May 2012
    Ireland
    My A6 Allroad 2.7 TDi quattro has what are very similar issues to yours. I haven't gone down the road of changing the DMFW but mine is automatic gearbox so I am not sure if such a DMFW exists in mine.
    I have been advised that it could be a flywheel problem.
    First gear in mine the pull seems fine but when the engine is cold there is a snick noise when the first gear change happens. This doesn't always happen.
    The other symptoms in mine are that the grating/slippage noise is noticeable in 2nd/3rd/4th/5th. If I accelerate the car the noise goes away and the pull seems normal. This grating/slippage noise is intermittent.
  1. Cost of replacement clutch and Dual Mass Flywheel (2.0TDI)
    By rufus2005 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-08-2018, 09:47 AM
  2. dual mass flywheel & clutch
    By wozbwfc in forum Bora - 1998 - 2005
    Last Post: 22-02-2011, 09:42 PM
  3. Mk4 115bhp TDI : Dual Mass Flywheel & Clutch
    By andyblack in forum Golf MK4 - 1999 - 2004
    Last Post: 17-12-2009, 12:05 PM
  4. clutch replacement needs new dual mass flywheel???
    By mrobson in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-06-2008, 10:56 AM
  5. Dual mass flywheel and Clutch
    By nano in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-01-2008, 08:38 PM
