I can only offer advice from the perspective of a Passat owner, which has a similar key - it is really easy to jump in and 'rush' the procedure and end up with the car not starting. Be slow and methodical with it, and make sure that your seat is in the right position too so that you are getting the clutch fully depressed. Hopefully, it will just be a case of you getting used to it.
