Thread: Audi A4 B8 TDI 170 correct starting procedure
  1. Audi A4 B8 TDI 170 correct starting procedure
    Jul 2009
    Camelford UK
    I have a recently purchased a 2010 A4 B8 Avant TDI 170 from an Audi main dealer. Despite following the manual to the letter, the engine starting is problematical. Sometimes it starts normally and on others pressing the key fob to start the engine appears to turn the ignition off. I am holding the clutch down as advised but the problem still continues erratically. The car is still under warranty but as my nearest dealer is over 50 miles away, any advice would be appreciated as to whether this is a known problem that needs attention, or is it something I am not doing correctly in the starting procedure.
    Thank you
    Chris L Hall
  2. Re: Audi A4 B8 TDI 170 correct starting procedure
    46 Post(s)
    hold in clutch and hold in the key until it starts and it will start everytime
  3. Re: Audi A4 B8 TDI 170 correct starting procedure
    Apr 2010
    Ashford, Middlesex
    I can only offer advice from the perspective of a Passat owner, which has a similar key - it is really easy to jump in and 'rush' the procedure and end up with the car not starting. Be slow and methodical with it, and make sure that your seat is in the right position too so that you are getting the clutch fully depressed. Hopefully, it will just be a case of you getting used to it.
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  4. Re: Audi A4 B8 TDI 170 correct starting procedure
    Jul 2010
    Clitheroe, Lancs
    I rush all the time! I never have a issue? Even a quick press of the button will start the car, and when it's cold it takes a few seconds after the quick press to start.
    Chris G ~ ~
  5. Audi A4 B8 TDI 170 correct starting procedure
    May 2012
    Lincoln
    Sometimes there is a slight delay in mine I assume this is related to diesel preheat as the amber light is on. This only happens on the first start of the day, so ignition on, clutch in and then press to start (hold in) and wait if necessary.
  1. Question What do you think of the Audi A4 2.0 Tdi Quattro 170
    By iworld in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-05-2011, 07:34 PM
  2. Golf Mk5 GT TDI (170) Starting Problems
    By craigrule in forum Golf MK5 - 2004 - 2009
    Last Post: 11-01-2010, 11:34 AM
  3. audi a4 170 tdi
    By m7rcu in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-10-2009, 06:51 PM
  4. Question Can nayone expain the correct procedure for bleeding a brake system
    By tsam19 in forum Golf MK3 - 1993 - 1999
    Last Post: 09-08-2009, 11:30 AM
  5. Correct seat removal procedure
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-03-2009, 11:07 PM
