Thread: Engine shuts off after starting
Results 1 to 10 of 13
  1. Engine shuts off after starting
    Oct 2012
    Huntingdon, Cambs, UK
    Hey everyone,
    I have a 1996 Audi A4 2.6L V6. I've been having problems recently with starting the engine. This does not happen all of the time, but it is starting to happen more often now that it is getting colder out. When I start my car it'll rev up to ~1.3K RPM, stay there for about 2 seconds and then the engine will cut out. The second time I do it, it never starts, it goes up to about 500RPM and dies. The third time is usually when it would always start with no problem, except for today. Today it took me about 10 tries (with a minute or two break in between each try) to get it started. It usually only happens on the first start of the day but it has happened more than once a day.
    Any insight would be greatly appreciated and if you need any more information from me, I'd be glad to give it to you.
    Thank you
  2. Re: Engine shuts off after starting
    Bournemouth
    have you tried changing the battery in your keyfob? i have similar symptoms to this occasionally, change the keyfob battery and all is ok again. basically its the immobiliser not getting a decent enough signal from the transponder and then killing the engine.
    worth trying as a starting point for approx £2
  3. Re: Engine shuts off after starting
    Pembrokeshire
    22 Post(s)
    unfortunately, the imobiliser chip s not connected to the battery in the key fob. it is just a chip that is read by the ecu. the battery is just for opening and closing the doors.
    your fault could be the imobiliser though, but the best place to start would be a fault code read, to see what the ecu says is wrong. there are so many things it could be you see, that a code read is the only place to start.
    welcome to the forum as well
  4. Re: Engine shuts off after starting
    Aug 2011
    Meath
    Transponder is probably a bit tired they cost a fiver but you need to get the pin to get the key coded. (vag-tacho works fine on older audis)
  5. Re: Engine shuts off after starting
    Bournemouth
    oops. Sorry.
    is that a b5 thing? Or is that common across other models? (Like mine for instance b6 cab)
  6. Re: Engine shuts off after starting
    Pembrokeshire
    22 Post(s)
    it is common to basically every car that has an immobiliser chip in the key. the chip is read by the aerial on the ignition column and if it reads ok, switches the ecu to start mode. the battery in the fob powers the signal to open and close the doors. the funny thing is, changing the battery should never help starting problems, but the amount of people that have said it does makes you wonder sometimes. the old rovers circa 1990's used the signal from the fob to switch the immob off and had no key chip, but these were too easy to bypass, so in those a flat battery meant no start, but most other cars use a chip.
  7. Re: Engine shuts off after starting
    Bournemouth
    cheers zollaf, every days a school day so strange that its happened a couple of times on my car, and I'm sure I get immobiliser warning lights. A new battery has sorted it straight away!
  8. Re: Engine shuts off after starting
    Pembrokeshire
    22 Post(s)
    well i would welcome someone to come along and tell me i am talking out my rear end
    will yours still start if you unlock it with the key and not the fob ?
  9. Re: Engine shuts off after starting
    Bournemouth
    In general? Or when the car is having starting issues?
    im unsure on both counts, but will try tomorrow.
  10. Re: Engine shuts off after starting
    Pembrokeshire
    22 Post(s)
    just in general.
  1. How to clean door shuts?
    By Guest 2 in forum General Detailing/Cleaning Questions
    Last Post: 28-04-2013, 08:40 AM
  2. How do you clean door shuts?
    By Perry in forum General Detailing/Cleaning Questions
    Last Post: 11-07-2011, 03:46 PM
  3. Please Help Car shuts off randomly.
    By brokentoe in forum Golf MK3 - 1993 - 1999
    Last Post: 15-10-2009, 09:45 PM
  4. Volksdevil.com shuts down
    Last Post: 19-08-2009, 05:42 PM
  5. Engine shuts down after high rpm 1.9TDI
    By Mida11 in forum Archive posts
    Last Post: 05-12-2007, 05:53 PM
