Thread: VW Lupo 1.0 MPI - AUC - cambelt
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 44
  1. Re: VW Lupo 1.0 MPI - AUC - cambelt
    131 Post(s)
    1978 Post(s)
    They are knowing for burning exhaust valves.
  2. Re: VW Lupo 1.0 MPI - AUC - cambelt
    Sep 2009
    Burton Upon Trent, England
    Thanks again, i have uploaded the instructions on whats been done, pretty sure that the engine itself is OK, i'll keep you posted thanks to all
    Lupo 1.0 Litre AUC Cambelt - YouTube
  3. Re: VW Lupo 1.0 MPI - AUC - cambelt
    Sep 2009
    Well ran VAS again gone through all diags all appears OK, So have to scratch my head again.
    Will update as soon as i make progress.
  4. Re: VW Lupo 1.0 MPI - AUC - cambelt
    Sep 2009
    Well, checked compression all around 12 bar.
    Cam sensor - gives square wave
    Crank sensor/ engine speed - gives a pulsed signal
    Fuel injectors all pulse fuel.
    Fuel pressure - 2.5 bar and holds pressure for a while
    Sounds like the timing as if its firing in the exhaust??
    VAS and VAG-COM find no fauls
    but i have noticed that i couldn't rest service interval on either - had to do it with the Cluster button.
    Also it doesn't give any veicle info on that option - is it too limited on the Lupo??
    anyway alos noticed that the workshop WSC are different for the Immo and ECU but the other info VIn and ID look the same.
    So i'm thinking Coil trigger Amplifier or ECU..
    I'll keep you posted.
  5. Re: VW Lupo 1.0 MPI - AUC - cambelt
    Sep 2009
    This was the original code error..
  6. Re: VW Lupo 1.0 MPI - AUC - cambelt
    Sep 2009
    Sorry had to shrink it under 2MB but hope its of help to someone.
  7. Re: VW Lupo 1.0 MPI - AUC - cambelt
    #17
    Aug 2011
    Meath
    Are the valve seats ok? any leaks on manifold? was the head pressure tested? was the correct head gasket used? This is a bit puzzling.
    Quote Originally Posted by Lambretta View Post
  8. Re: VW Lupo 1.0 MPI - AUC - cambelt
    #18
    Sep 2009
    Quote Originally Posted by paulkennedy View Post
    Hi paulkennedy,
    I have to agree..
    I've built lots of engines over the years and this one has me puzzles too, Yes valve seats were tested by putting fuel in the ports and seeing if it leaked through valve head.. the compression levels are all the same(telling me that all valves are as should be) i even did a fuel leak test on the Pistons and nothing got past any. i contacted VW and ask for a ring price before test (£8.xx each set)then asked how many he sold, he checked the history and he has never ordered any.
    No leaking head gasket as the water asn't moved, when i removed plugs and they just smelt of fuel.
    Can't see a leak for the inlet manifold and new seals fitted and checked
    The only thing i did was mixed up plug leads once but that was rectified as being 1=A, 2=C, 3=B, 4=D
    I'm leaning on engine management or Coil amp causing misfire..
  9. Re: VW Lupo 1.0 MPI - AUC - cambelt
    #19
    Sep 2009
    Here is a better link of whats been done Lupo-2.mp4 video by CALVIN- - Photobucket
  10. Re: VW Lupo 1.0 MPI - AUC - cambelt
    #20
    Aug 2011
    Meath
    I'm almost tearing my few remaining hairs out thinking about this thats why I avoid petrol engines. Are all the plug leads and coil packs good? I got this infor from here
    http://the-corrado.net/showthread.ph...misfire/page2&
    they say leads are connected
    A is plugged to cylinder 1
    B to Cylinder 3
    C to cylinder 4
    and D is cylinder 2
  1. 1.0 MPi AUC engine, EGR valve problem?
    By Freeranger in forum Polo - Derby - Lupo - Fox
    Last Post: 13-05-2012, 07:03 PM
  2. lupo 1.0 mpi cuts out when moving
    By terbotron in forum Polo - Derby - Lupo - Fox
    Last Post: 01-10-2009, 11:31 PM
  3. Cambelt interval Fabia 1.4 mpi AQY
    By tristy in forum Fabia
    Last Post: 25-01-2009, 09:25 PM
  4. Lupo Cambelt Change - What do I need?
    By skink in forum Polo - Derby - Lupo - Fox
    Last Post: 10-07-2008, 11:49 PM
  5. LUPO 1.0l MPI Misfire Cyl2
    By ademason in forum Polo - Derby - Lupo - Fox
    Last Post: 28-03-2007, 11:14 PM
