Thread: Wet carpets water leak
  1. Wet carpets water leak
    Feb 2010
    Kelso UK
    Have had my A4 6mths and has been left outside all the time. No problem until now, but just discovered carpets on right side of car absolutely soaking wet. Don't know when this happened as haven't cleaned car out for a few weeks, but there hasn't been condensation in the car recently so I suspect the water has only just got in. RAC (yes Audi assist has to be used first rather than taking to dealer) checked main possibilities and found no problems so car will now have to go in for more thorough check. It has been very wet recently but so was the summer! Anyone else has similar problem; I know that all windows and doors have been fully shut all the time.
  2. Re: Wet carpets water leak
    Oct 2005
    Quote Originally Posted by tourer2 View Post
    It's one of the most common issues on the forum.
    Search plenum chamber or wet carpets and go nuts
  3. Re: Wet carpets water leak
    135 Post(s)
    2042 Post(s)
    This is the first time I have heard of it on an 8K A4, you would think they had solved it by now!
  4. Re: Wet carpets water leak
    Oct 2005
    Yup, I realised that after posting, it's also the driver's side too, which isn't as common.
    Hopefully it's a door/window seal rather than the usual failure.
  5. Re: Wet carpets water leak
    Mar 2010
    linlithgow uk
    I had the same problem, the car was only 5 months old. The car ended up in Audi twice. Second time they discovered a leak behind the glove box. They said it was to do with the seal on the bulkhead. They ended up having the car for a week. The wing was removed to rectify the problem. If it is under warranty ask them to take it into their bodyshop.
  6. Re: Wet carpets water leak
    Feb 2010
    Kelso UK
    Car now fixed. Cause of water ingress was ' incomplete body sealant at o/s bonnet hinge area' somewhere behind 'fuse block'. Seems to be OK now although I noticed yesterday that owners manuals in glove box have that damp paper feel to them, so will have to keep checking. Car was with the dealer for 2 weeks in total, they gave me a replacement car and a slug of diesel for my car so can't really complain about them. As for Audi quality control, that's not so good.
  7. Re: Wet carpets water leak
    Mar 2010
    linlithgow uk
    Glad your problem is now solved. Great site for sharing information.
  1. How To Passat water leaks - wet carpets
    By Invictagunner in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-03-2020, 09:43 AM
  2. Just got an '02 A4 Wet carpets
    By nilocp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-08-2012, 09:35 PM
  3. Water, wet carpets, indicators stuck on, remote locking duff
    By TonyWilk in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-08-2010, 10:06 PM
  4. Question Wet Carpets
    By Gary.Townend in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-05-2010, 04:00 PM
  5. Help! Wet carpets
    By Simpsvag in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-03-2009, 12:04 AM
