Thread: Automatic Start\Stop not working
  1. Automatic Start\Stop not working
    Oct 2012
    We have a 2009 '09' Passat Estate (Bluemotion 2).
    The auto start\stop use to work happily but now I have noticed it does not work.
    The manual mentions some criteria which needs to be met and i'm fairly confident all of these have.
    Something which is strange is that on the instrument cluster there is no information displayed regarding the status of the Start\Stop system (Example. If you used to hold the button for auto start\stop next to the gear stick the dash would display the 'A' with a slash through it indicating that the system is disabled) this does not happen anymore, there is no info at all displayed. The auto start\stop button by the gearstick does illuminate (with dash lights and goes orange when pushed in for 2-3 seconds)
    I have a ross-tech VCDS cable and have scanned the modules but no errors are been detected.
    My guess is the battery could be weak (Check with multimeter and its above 12v) and the car gets driven a good 65 miles per day and has been starting fine with ever lowering temperatures (So far...)
    My next suspicion is something like the interior sensor has died and thus preventing the system from working? (Can you check this in VCDS?)
    However, my 2 ideas could be rubbish as I would of thought you would still see info displayed on the dash regarding the status, ie, disabled or not available etc.
    Could it be a fuse?
    Thanks for any tips, failing that ill have to drop it in to a garage from them to try and fix.
  2. Automatic Start\Stop not working
    Oct 2012
    No one have any ideas?
  3. Re: Automatic Start\Stop not working
    SE London
    Post your full VCDS Autoscan here? Then those knowledgable will see what modules and codings you have?
  4. Automatic Start\Stop not working
    Oct 2012
    Good plan. I'll post it up tonight.
  5. Re: Automatic Start\Stop not working
    Oct 2012
    Here is the VCDS Log file for the autoscan function:
    Wednesday,17,October,2012,17:31:57:07082
    VCDS Version: Release 11.11.4 (x64)
    Data version: 20120807
    Chassis Type: 3C0
    Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 56 61 6C
    VIN: WVWZZZ3CZ9E085035
    01-Engine -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    6C-Back-up Cam. -- Status: Malfunction 0010
    Address 01: Engine (CBD) Labels: 03L-906-022-CBA.clb
    Part No SW: 03L 906 022 SC HW: 03L 907 309 B
    Component: R4 2,0L EDC G000SG 4081
    Revision: 22H21--- Serial number: VWZCZ000000000
    Coding: 0000071
    Shop #: WSC 00595 210 83429
    VCID: 78D133020BC8E1D8195
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
    Part No SW: 3C0 614 109 M HW: 3C0 614 109 M
    Component: J104 C4 440 V2 0021
    Revision: --025--- Serial number: 00000786397099
    Coding: 0036344
    Shop #: WSC 05311 000 00000
    VCID: 287123429BE8B158495
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No SW: 1K0 820 047 JD HW: 1K0 820 047 JD
    Component: Climatic PQ35 143 1313
    Revision: 00143033 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 6FC3085E7E86A660C8F
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
    Part No SW: 3C8 937 049 R HW: 3C8 937 049 R
    Component: Bordnetz-SG H53 3101
    Revision: 00H53000 Serial number: 00000009080005
    Coding: 81880F2700041A00470A00000F00000000005D435C00010000 0100000000
    Shop #: WSC 05124 123 12345
    VCID: 40A19BE213986918615
    Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer 311008 022 0601
    Coding: 00046997
    Shop #: WSC 05124
    Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
    Part No SW: 3C8 919 475 HW: 3C8 919 475
    Component: PARKHILFE 8K H07 0007
    Revision: -------- Serial number: 97540834413310
    Coding: 300003
    Shop #: WSC 05314 000 00000
    VCID: F1C78E2628B230905EB
    Address 15: Airbags Labels: 5N0-959-655.lbl
    Part No SW: 5N0 959 655 HW: 5N0 959 655
    Component: J234__041 VW10 HI 1815
    Revision: 19013000 Serial number: 0039BPRH3NQF
    Coding: 0013361
    VCID: FAD5A90AB5C473C8EF1
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 AD HW: 3C0 953 549 AD
    Component: J0527 0020
    Revision: 00026000 Serial number: 3C9953507CL
    Coding: 0000014
    VCID: 6EFD155A798CAF68C39
    Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
    Part No SW: 3C0 920 971 R HW: 3C0 920 971 R
    Component: KOMBI H04 0107
    Coding: 460F00
    Shop #: WSC 05314 115 00000
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
    ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod
    VCID: 3449C7329F20C5B8F5D
    Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
    Part No SW: 3C0 907 530 M HW: 3C0 907 951
    Component: J533__Gateway H14 0158
    Revision: H14 Serial number: 0721G08C17007E
    Coding: F9A01F06404203042003
    VCID: 2B7BDC4E8A1E9A40A47
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 AQ HW: 3C0 959 433 AQ
    Component: IMMO 044 0383
    Revision: 00044000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 79D7360630C2F8D066B
    Part No: 3C0 905 861 G
    Component: ELV 027 0380
    3C0905861G ELV 027 0380
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 1T0 035 680 D HW: 1T0 035 680 C
    Component: RNS-MID H55 4020
    Revision: AB001001 Serial number: VWZ6Z7L9201086
    Coding: 0400040004000080000B
    Shop #: WSC 12345 123 12345
    ASAM Dataset: ------------------------- ------
    VCID: 2F43C85E7E06E66088F
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
    Component: J386 TUER-SG FT 1518
    Revision: 72009005 Serial number: 00000766789122
    Coding: 0000565
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 F
    Component: EPS_ZFLS Kl. 195 2701
    Revision: 00H15000
    Shop #: WSC 02069 000 90108
    VCID: 2D7FD256B40A9470BA3
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 044 0612
    Coding: 1891020851030E7630049C1D70081BCE103C01
    Shop #: WSC 05311 123 12345
    Part No: 1K0 951 605 D
    Component: LIN BACKUP HORN H08 9001
    Part No: 3C0 951 171 C
    Component: Neigungssensor 004 0611
    Component: Innenraumueberw.004 0611
    Address 4F: Centr. Electr. II (J533_) Labels: 1K0-907-532.clb
    Part No SW: 1K0 907 532 HW: 3C0 907 951
    Revision: -------- Serial number: 0721G007E08C17
    Coding: 00000000
    VCID: E6EDED7A117CE7283B9
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
    Component: J387 TUER-SG BT 1518
    Revision: 72009005 Serial number: 00000773089127
    Coding: 0000564
    VCID: 70C10B2263B8B998D15
    Address 53: Parking Brake Labels: 5N0-907-801.clb
    Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
    Component: J540 EPB3 VW-10498 0003
    Revision: 009 Serial number: 00000000225980
    Coding: 0000056
    Address 56: Radio (J0506) Labels: 1T0-035-680.clb
    Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
    Part No SW: 1K0 907 534 HW: 3C0 907 951
    Component: Batt.regelung H14 0158
    Coding: 0301085A
    VCID: E8F1E3421B68F158095
    Subsystem 1 - Part No SW: 1K0 915 181 B HW: 1K0 915 181 A
    Component: J367-BDM H07 0121
    Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
    Part No SW: 3C0 907 441 HW: 3C0 907 441
    Component: J772__Rearview 0042
    Revision: 00H05000 Serial number: PA8 J8X1035
    Coding: 0020007
    VCID: DFE3F89E0E26B6E0F8F
    1 Fault Found:
    03006 - Back-up Camera System not calibrated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 246
    Time Indication: 0
  6. Re: Automatic Start\Stop not working
    Oct 2012
    I connected to 61 (Battery Regulator) and measured some values...
    Address 61: Battery Regul. (1K0 907 534 )
    18:11:18
    13.0 % Battery Level
    10.0 % Battery Condition (MMI-Display)
    63.0 % Battery Aging (Power)
    84.0 % Battery Aging (Charge)
    7.0 mOhm Internal Resistance Battery
    5.6 mOhm Internal Resistance Battery (normalized)
    0 Ah Available Battery Charge
    11.60 V Battery Quiescent Current
    Inactive Automated Engine Stop
    Inactive Automated Engine Re-Start
    active Start/Stop Inhibitor
    Id assume the battery is not long for this world and should be replaced and is causing the problem?
  7. Re: Automatic Start\Stop not working
    Norfolk
    Yes it looks like the regulator has turned off stop/start due to poor battery performance.
  1. How does Start/Stop interplay with Stop-Go on the ACC?
    By Timothy Nathan in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-02-2012, 11:40 AM
  2. start - stop (or rather not)
    By ti rich in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-02-2012, 10:28 PM
  3. Stop/Start not working?
    By breedop in forum Bluemotion
    Last Post: 10-06-2010, 08:55 PM
  4. Start Stop
    By Tony2 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-03-2010, 09:32 AM
  5. Stop/Start
    By Toltol in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-02-2010, 09:06 AM
