Thread: Dashboard Cluster Fault
Results 1 to 10 of 17
  1. Dashboard Cluster Fault
    Leicester
    Have a fault with the above, no power to the unit whatsoever. Had the AA come out and run some tests and diagnose the problem. having looked on the net, I understand this is a common fault with Audi's. To replace its looking like the best part of £1,000! Obviously not happy at all after only having the car for 2 months!! Not covered in the warranty.
    I also noticed a few companies offering repairs at a more reasonable cost. Can anyone recommend anyone inparticular or spread any more light on the problem?
    Thank you in advance.
    Car is: Audi TT FSI 2007
  2. Re: Dashboard Cluster Fault
    2019 Post(s)
    New shape or old shape TT?
  3. Re: Dashboard Cluster Fault
    Leicester
    New shape TT
  4. Re: Dashboard Cluster Fault
    2019 Post(s)
    As far as I can see the cluster is just under £500 and with even Audi labour that should be around £620 fitted. I have not seen a type 8J cluster go faulty yet but you could try giving BBA Reman a call on 01634 687222 as they have repaired the previous generation TT dasher for me.
  5. Re: Dashboard Cluster Fault
    Leicester
    Great, thanks for the advice. I have just spoke to Lions (car Garage) and they recommend I send it to the company they use. It's called ECU Testing, they charge £165.00 for the repairs. They even said go direct with them to cut them out as the middle man as it will save me some money.
    Failing that, I will give BBA a call. Would you know the part no. for the cluster itself? I can't seem to find it.
    Appreciate your advice. Very helpful. Thanks
  6. Re: Dashboard Cluster Fault
    2019 Post(s)
    yes I know the company in question, they are near my wife's place of work, quite close to us here and I don't use them, I use BBA I cannot say any more. Their are dozens of different clusters, I would need your cars chassis number.
  7. Re: Dashboard Cluster Fault
    Leicester
    ok, GREAT. The chassis no. is TRUZZZ 858 710 376 76
  8. Re: Dashboard Cluster Fault
    2019 Post(s)
    That chassis number is slightly wrong, can you PM me the reg?
  9. Re: Dashboard Cluster Fault
    Aug 2007
    Newport, Wales
    7 Post(s)
    My TT has been running fine since I got it about 3 months ago.
    I started the engine tonight but noticed there was no sign of life on the instrument cluster... the engine cut out after a few seconds (the instrument cluster fuse tested ok). The car locks / unlocks just fine, so some modules are clearly still working.
    I can hear a pump running constantly, even when the keys arent in the ignition. Removing relay 643 stops it. Is it the dreaded instrument cluster failure do you think?
    Regards
    Al
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  10. Re: Dashboard Cluster Fault
    Aug 2007
    Newport, Wales
    7 Post(s)
    There seem to be a number of people re-building clusters:
    • Crasher suggested the service from BBA Reman (price is £35 for testing, £125 for the repair plus shipping on top. All + VAT) 3 working day turn-around.
    • rc4279 suggested ECU Testing in Derby (£195 +VAT) - (they seem to have gone up in price since you posted rc4279!)
    • Has anybody clocked the repair service (excuse the pun!) from Cartronix? (£150 inc VAT).
    If Crasher has good experience with BBA Reman, then that's probably the way to go. Who did you use in the end please rc4279?
    [ Edit to update the BBA Reman prices ]
    [ Past Audis:
    A6 S-Line 3.0
  1. Leon 1.6 cluster fault
    By badade 1.8t in forum Leon
    Last Post: 06-07-2012, 06:44 PM
  2. Rear Light cluster fault
    By chris7700 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-02-2011, 10:10 PM
  3. Please Help Dashboard Cluster issues, rev counter, oil light and speedo
    By shaiboy_uk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-12-2009, 11:31 AM
  4. dashboard light cluster HELP PLEASE
    By trioptics130 in forum New Member Introductions
    Last Post: 16-12-2009, 12:26 PM
  5. Audi a6 dashboard cluster
    By mmm777 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 28-06-2007, 10:24 PM
