Thread: indicator problem
Results 1 to 10 of 12
  1. indicator problem
    Apr 2007
    i have a problem on my A6..
    when i put the indicator on to turn left or right, it just lights up with no ticker..
    the lights come on but there is no blinking, can anybody help...
    audi a6 1.9 tdi avant 2004
  2. Re: indicator problem
    Sep 2009
    United Kingdom
    Either the hazard relay is on the fritz and needs replacing or its water in the ccm under the passenger footwell carpet, i would have thought anyway.
  3. Re: indicator problem
    Dec 2008
    Ely, Cambs
    Yep I'd agree with Snaga
  4. Re: indicator problem
    Apr 2007
    thanks lads..
    its weird because if i press the hazard switch that works okay, then the indicator works too..
    a few minutes later the indicator stops working...
    what part am i asking for, is it the Hazard switch relay ?
  5. Re: indicator problem
    Aug 2011
    Meath
    Give it a scan first, as Snaga says it could be the CCM under the carpet thats damp
  6. Re: indicator problem
    Mar 2008
    High Wycombe
    The hazards will work properly. There's 2 relays in there - one for the hazards, another for the indicators. The indicator one always fails first.
    The part to ask for is the hazard switch. The relays are inside it.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  7. Re: indicator problem
    Apr 2007
    cheers nick..
    do you know how you get this hazard switch out ?
    i wanted to take a look so that i know what i am doing..
    i have got the facia trim off and the switch looks like it is held in with spring clips somewhere, are these clips left to right ?
    the gap to get anything in to take them out is very small, so not sure what i will use.
  8. Re: indicator problem
    Aug 2008
    saundersfoot
    I have a similar problem and have just bought a hazard switch and when I put it in it makes more noise than the old one did, my problem is when I cancel the indicator the relay carries on ticking for a bit longer then stops. I have taken out the unit underneath the carpet and the problems is still the same. There is a thread somewhere that has some good pictures of getting the relay out, it is what I used but the wire into the back of it is so short, you have to stretch it a bit with some clever use of flat screwdrivers to hold it in place when you plug it back in. I may aswell sell you the new one I bought if you are interested, as it did not cure my problem.
    04 allroad 2.5tdi v6,Hotchkis sports sway bars,pentagon glass,Sachs performance clutch,OEM RS6 spoiler, Arnott gen 11 air springs front with OEM shocks, rear with bilstein s4 shocks,Longlife stainless exhaust,Led interior lights,HEL braided brake hoses,Brembo 18Z 6 pot calipers,345mm amg discs ebc red stuff pads,allroad 4.2 rear calipers + vented disc,OEM Xenon Headlights,Camei grill,18" 8.5J RS4 alloys,yokohama wintrac 245/45/18 xl.
  9. Re: indicator problem
    Aug 2008
    saundersfoot
    reading into some past threads apparently the stalk is the cause of this and it needs a good clean and spray with lube. will be doing this tomorrow.
  10. Re: indicator problem
    Apr 2009
    Surrey
    183 Post(s)
    Quote Originally Posted by vwnige View Post
    cheers nick..
    You need to grab the edge of the switch with a pair of needle nosed pliers and pull. As you are replacing the switch you do not need to worry too much about damaging it. This article (AudiWorld Tech Articles) may help you as it shows where the springs are. Also this article (AudiWorld Tech Articles) shows how to get to the indicator stalk if that proves to be the problem
  1. A4 1.8 Indicator problem
    By parapilot in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-04-2010, 05:58 PM
  2. Indicator Problem
    By Hembrowr in forum Polo - Derby - Lupo - Fox
    Last Post: 28-02-2010, 07:40 PM
  3. Indicator Problem - help!
    By winker in forum Audi A3 - Archive Topics
    Last Post: 26-09-2008, 11:49 AM
  4. Indicator problem
    By Sibbs in forum Audi A3 - Archive Topics
    Last Post: 10-07-2008, 09:55 PM
  5. A different indicator problem
    By alogbe in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-01-2008, 08:47 PM
