Thread: Can you fit cruise control on a car that didn't come with it?
Results 11 to 20 of 23
  1. Re: Can you fit cruise control on a car that didn't come with it?
    Dec 2008
    Ok thanks. The pic of the grey(8P) A3 s my current car - it's a 2004 2.0L TDI with BKD Engine if that helps?
  2. Re: Can you fit cruise control on a car that didn't come with it?
    Jan 2012
    Coding Something
    Well I suspect you'll need a module to code cruise tbh given age, not many back then had compatible modules fitted.
  3. Re: Can you fit cruise control on a car that didn't come with it?
    Dec 2008
    What sort of module is it I'd need? Wold it replace an existing part or wold it be a whole new part?
  4. Re: Can you fit cruise control on a car that didn't come with it?
    Jan 2012
    Coding Something
    You need to get vcds on to check module 16 & see if it codes for cruise, if not this needs replacing.
  5. Re: Can you fit cruise control on a car that didn't come with it?
    Dec 2008
    Right so almost exactly a year after first thinking of this - I'm finally getting round to it.
    ive found this on ebay AUDI A3 8P1 (2007) 2.0 TFSI (BWA) INDICATOR + CRUISE CONTROL STALK - 8P0953513 | eBay - its from a newer car (57 whereas mines 54) does anyone know if it will be compatible? It says from 2003-2013?
  6. Re: Can you fit cruise control on a car that didn't come with it?
    Dec 2008
    Ive looked in the handbook and mines an 8P1 BLC
  7. Re: Can you fit cruise control on a car that didn't come with it?
    #17
    46 Post(s)
    You still need to check whether your steering control unit is compatible with cruise.
  8. Re: Can you fit cruise control on a car that didn't come with it?
    #18
    Dec 2008
    Right - just spoken to Audi - the steering module on mine is 8P0953549G - he reckoned it would be compatible with no extra bits.
    Also - I've been looking at a cruise stalk on ebay - thats come out of a 57 plate A3 (mines 54) - any idea if it will work? The chap from audi said they changed it in 2007, but can't confirm if it affected 57 plate cars
  9. Re: Can you fit cruise control on a car that didn't come with it?
    #19
    46 Post(s)
    OK seems it is indeed compatible with cruise.
    Stalks only changed on 2010+ cars where it became a spring back for the dipped beam and incorporated something else. But everything from 04-09 afaik is the same except the little pictures on the stalk might've been altered.
  10. Re: Can you fit cruise control on a car that didn't come with it?
    #20
    Dec 2008
    Excellent! So what controls the throttle? Is it electronic?
    also - I know someone who's breaking an R reg A8, which has cruise, would that stalk work on my a3? I. Assuming probably not due to the age difference?
  1. Question Retro Fit Cruise Control...
    By ToMBoY_C in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-12-2010, 11:49 PM
  2. retro fit cruise control
    By taff503 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-05-2009, 04:32 PM
  3. Cruise Control Retro-Fit
    By Judd222 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-11-2008, 08:43 AM
  4. Question retro fit cruise control
    By Mr.I Kenney in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-07-2008, 04:18 PM
