Thread: damp smell from heater a3
  1. damp smell from heater a3
    Oct 2012
    london uk
    Hello all,
    Have a 2005 Audi A3 5door 2.0 tdi, which has a damp smell coming from the climate control. Have tried changing the pollen filter and regasing the ac system but now realised it seems to be worse when temp is set to "HI". Wasnt to bad in the summer (What we had of one) but now seems to be even worse whenever it rains. Also have noticed the windscreen is misting up when the has been sat over night and gets even more fogged up when the blowers are turued on in the morning. Any ideas where the water could be getting in??
  2. Re: damp smell from heater a3
    Dec 2007
    8 Post(s)
    Quote Originally Posted by Dev.G View Post
    Hello all,
    If your model is similar to the 2001 one, there is a possibility that water is entering pollen filter from a poorly fitted plastic scuttle at bottom of windscreen
    Was the pollen filter that you replaced completely dry?
    If water is getting in here it needs to be eliminated as it causes electrical problems.
    Regards
    Michael
  3. Re: damp smell from heater a3
    Oct 2012
    london uk
    replaced the pollen filter about 3 months ago and it was dry then, just checked it again now and was a little dusty and smelly but dry as a bone. Every thing else in the vacinity seems to be dry and free from any water maks aswell.
  4. Re: damp smell from heater a3
    Dec 2007
    8 Post(s)
    I suppose the process of elimination is next
    Are the footwells dry under carpets
    There are some posts regarding disinfecting a/c for bacteria.
    I have come across a plastic funnel type drain from a/c in an A6 which was blocked, it emerges through bulkhead n/s to engine bay but is concealed by
    sound insulation material. (not sure if A3 is same)
    I expect if you were to use a/c for a period and parked on a dry surface you should see water emerging from drain area, if no water emerges it may be coming in to footwell.
  1. heater, air con smell
    By rosieandjim in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-08-2010, 09:34 PM
  2. Question damp smell & wet windscreen
    By FLENG2008 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-12-2009, 10:15 PM
  3. Question PLEASE HELP! - Musty Damp SMELL in 2006 vw passat
    By saunders400 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-05-2009, 08:14 AM
  4. Damp smell coming from blowers
    By ayresy101 in forum Passat - Archive Topics
    Last Post: 29-08-2007, 01:59 AM
  5. Damp smell
    By pricey in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-06-2007, 05:14 PM
