Thread: Tyre Pressure Monitoring
  1. Tyre Pressure Monitoring
    Oct 2011
    Gourock, Scotland
    Recently had 2 x front tyres fitted. One in July and one 2 x weeks ago. However, 3 x tyres are at 30 psi and one at 33psi (newest one). I deflated this (as I have a gauge) to the same but no alarm triggered. I have a feeling that the person that changed the tyre has not swapped over the sensor. Who is responsible for that ? The guy fitting the tyre or does it lie with me to inform him?. I just assumed that they would have noticed this
  2. Re: Tyre Pressure Monitoring
    UK Ex-pat now in Australia
    With the system you have as long as the tyre pressure is within the normal range of partial loaded tyres then no warning comes on - only if out of these values will it come on. The sensor is also the valve so probably not been touched just replaced the core of the valve stem - if there was a fault or not fitted then the light for tpm would be on permanently.
    Had MKV GTI, Now Ford Falcon
  1. Question Tyre pressure monitoring
    By satsu in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-12-2018, 08:27 AM
  2. Please Help Tyre Pressure Monitoring
    By pappasmurf in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-03-2012, 05:12 PM
  3. Retrofit Tyre Pressure Monitoring
    By GeoffW in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-08-2011, 10:18 AM
  4. Tyre Pressure Monitoring
    By theblacksurge in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-01-2011, 10:48 PM
  5. monitoring tyre pressure advice
    By weepiglet in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-02-2008, 02:28 PM
