Thread: RNS 510 Firmware Upgrade - Skin Change
  1. RNS 510 Firmware Upgrade - Skin Change
    Oct 2012
    Middlewich, UK
    I am hoping someone can help me, I have just upgraded the firmware on my RNS 510 to version 3810 and after it had rebooted I have noticed that the skin has been reset to the default Highline one - I had Premium before hand.
    I really want to get the Premium skin back but have been told I have lost it due to long coding and the only way to get it back is via VCDS!!!! I have also been advised that even if I upgrade/downgrade the firmware it will remain on the Highline skin.
    If the firmware upgrade changed this is there no way software can be used to change it back again as I do not have access to a VCDS????
    Any help appreciated!!!
    2013 3.0TDI V6 Altitude - Deep Black Metallic, Dealer Fit Westfalia Detachable towbar with 13pin electrics, 850w cooling fan upgrade and Rear DVD Entertainment install
  2. Re: RNS 510 Firmware Upgrade - Skin Change
    Oct 2012
    Middlewich, UK
    Thanks to MFGF's kind assistance I have managed to get the correct skin back on my RNS510 via VCDS and some minor re-coding work!!
    0 2 0
  3. RNS 510 Firmware Upgrade - Skin Change
    Feb 2004
    Yorkshire
    49 Post(s)
    Could you post how this was done? You may help others
    Stuart
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Ways to support the website
  4. Re: RNS 510 Firmware Upgrade - Skin Change
    Oct 2012
    Middlewich, UK
    As I say I cannot take the credit for this as MFGF was kind enough to so this for me as he has the VCDS unit. However you need to go into 'Module 37 - Navigation' and then using the long coding helper go into Byte 7 and there is a drop down box at the bottom for "Bit 4-5 Display Variant" that allows you to change the skin to either 'Highline' (Default), 'Sportsline' or 'Premium'. Once the change has been made and sent back to the unit the VCDS needs to be disconnected and the RNS-510 rebooted by pressing and holding the < and > and I/star buttons until the unit reboots and the skin will have changed.
    The VCDS screen shot is below
  5. Re: RNS 510 Firmware Upgrade - Skin Change
    Nov 2012
    Leeds
    Hi wanna know about RNA 510 if u saved areas names would rns510 gives you street name list by pressing any latter
    thanks .
  1. RNS-315 to RNS-510
    By neilsafc in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 19-07-2011, 10:48 AM
  2. RNS 510 firmware update
    By cdgthreesalmons in forum Golf MK6 - 2009 - 2013
    Last Post: 11-10-2010, 09:59 AM
  3. RCD 510 Firmware
    By daclyn in forum Golf MK5 - 2004 - 2009
    Last Post: 23-07-2010, 09:43 AM
  4. RNS-E Firmware
    By rsymes2k in forum In Car Entertainment
    Last Post: 06-03-2009, 01:36 PM
  5. Please Help RNS-E Firmware upgrade - No satnav :(
    By wez130 in forum In Car Entertainment
    Last Post: 27-09-2008, 10:49 PM
