Thread: EPS/ABS Warning Lights
Results 1 to 10 of 19
  1. EPS/ABS Warning Lights
    Jun 2008
    L'Etang La Ville, France
    Hi Everybody,
    I have a problem with the EPS/ABS warning lights coming on. This only happens when I am stationary or creeping forward slowly like at traffis lights. It never happens while driving. If I stop the engine and retstart the lights go off. Even with the warning lights on the car drives perfectly normally. The car is A4 estate, petrol, automatic. After I have the problem with the lights coming on I restart the car with the brake pedal depressed as it is an automatic. When I release the brake pedal there is a grating noise which sounds like someting has been jammed and then released. Any help appreciated.
  2. Re: EPS/ABS Warning Lights
    134 Post(s)
    2020 Post(s)
    You need a code read first and then the wheel speeds need to be monitored as it sounds like one sensor is dropping out at slow speed, it may not have any codes stored so observing the wheel speeds is the only sensible way to fix it. This often happens after a CV boot has been changed.
  3. Re: EPS/ABS Warning Lights
    Jun 2006
    Cardiff
    Crasher is usually right about these things
    B6 A4 Avant 1.9 TDI 130 Sport (6) Moro Blue, GMBH S Line Kit, Decatted, remapped to 165bhp, EGR delete, Goodyear Eagle F1 Asy's, Full Leather, Cruise Control, Bose, Audi phone prep, Cool Glove Box, Parking Sensors, Rear privacy glass.
    Seat Ibiza 1.2 TSI FR 3 door Lima Green.
  4. Re: EPS/ABS Warning Lights
    Jun 2008
    Crasher,
    Many thanks for response. But is actually happening when the car is stationary. Just spent half an hour up and down the drive trying to replicate the problem. I've had it for about 2 years. Front discs and all break pads changed in meantime. It also very imtermittent. I can go for several weeks with no problem then it happens several times in one day. Dry and wet weather make no difference. Only trying to solve it as I want to sell the car.
  5. Re: EPS/ABS Warning Lights
    Jun 2006
    Cardiff
    As Crasher as already stated you need to get Vagcom/VCDs on it. The warning lights will have left a code in the ECU which should tell you where the fault is.
  6. Re: EPS/ABS Warning Lights
    Jun 2008
    Thanks Crasher and Paul,
    I'll let you know how I get on.
    Graham
  7. Re: EPS/ABS Warning Lights
    Jun 2006
    Cardiff
    If you have a laptop PC it's worth getting a USB OBDII cable off ebay (£25 for a decent one) & downloading free VCDS Lite from the Ross Tech site. Dealers usually charge about £80 for diagnosis so it'll pay for irself straight off. Don't buy a code reader they're a waste of money.
  8. Re: EPS/ABS Warning Lights
    Jul 2011
    Kilmarnock, Ayrshire, Scotland
    How do you know which cable is a decent one
    2008 A4 B8 Avant 143 2.0 TDI & 2014 Skoda Superb Comb 4x4 170CR 2.0 TDI DSG
  9. Re: EPS/ABS Warning Lights
    Jun 2006
    Cardiff
    Quote Originally Posted by rabmurray9121 View Post
    http://www.gendan.co.uk/product_VAGUSB.html
  10. Re: EPS/ABS Warning Lights
    Jun 2006
    Cardiff
    It's worth registering with Ross Tech as you get more functions. Ross-Tech: VCDS: Function Table
  1. EPS/ABS Lights
    By grahamchet in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-10-2012, 12:48 PM
  2. Replies: 1
    Last Post: 24-02-2012, 10:04 PM
  3. Please Help ABS and EPS lights stay on
    By mercer2773 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-06-2011, 11:16 AM
  4. Please Help abs eps and oil light help
    By km106489 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-08-2008, 08:09 AM
  5. abs and eps warning lights on
    By BROWN_OWL in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-08-2007, 08:50 AM
