Thread: The Noise Machine
Results 1 to 10 of 14
  1. Question The Noise Machine
    BuyanythingbutaVW Guest
    Hello all,
    Just wondering if anybody help diagnose two noises that my 55 golf tdi (130) has started making in the engine bay area. Car has done 41,000 miles and the main fault that it has ever had is an air take inlet valve replacement at about 20,000 miles.
    The first noise sounds like a hissing noise when driving and when the clutch is depressed, the noise lessens - usually happens when being driven hard and after about ten miles+. A quick search mentioned a noisy bearing for similar faults, but generally on much older or higher mileage cars.
    The second noise is from the turbo, with the turbo always sounding like a police siren. The turbo has always made a similar noise, albeit quieter, but has recently got louder and has made passengers heads spin round looking for approaching police cars. The turbo is also what I would describe as lumpy when changing gears and trying to pick up.
    The car is under warranty, but I wanted to ask the dealer to check the car and sound like I know what I am on about.
    Thanks a lot for any help that you can give.
    Jamie
  2. Re: The Noise Machine
    May 2006
    Exmouth, Devon, UK. Drives Bonkers Fabia Diesel. Has full VCDS
    Hmm, turbo could be being given dodgy signals due to a failing MAF sensor. The hissing noise has got me stumped, especially as it reduces when the clutch is in. Would you say it's just under power that it does it, and perhaps just lower down in the rev range? It could be the dual mass flywheel moaning if that's the case.
    Jason - Rather mad Skoda Fabia driver.... Odd whiff of diesel coming from him.
    260bhp Skoda Fabia TDI Dyno Run
    http://www.youtube.com/watch?v=9BvjJjL7Z50
    315bhp Skoda Fabia TDI Dyno Run (2013)
    http://www.youtube.com/watch?v=TOE4nbT5NGY
  3. Re: The Noise Machine
    May 2007
    Liverpool
    My turbo whistled a bit like a siren and it was goosed. If I were you i'd get it back to the garage before your warranty runs out, otherwise it cound cost you ££££. Do you let the turbo run down before switching the engine off, and wait about 60 secs when the engine is cold before setting off. This stops the turbo failing earlier than it should.
  4. Re: The Noise Machine
    In reply to a couple of queries that have arisen I would say that I just start and stop the car whenever I want. I didn't know that using your car when cold could damage a turbo.
    Also when I press the clutch in my car doesn't lose power. However the hissing (or to be more precise a 'putt, putt, putt, putt' noise at high and fast frquency) just lessens. It sounds possibly like a loose hose or something like that, but when I switch off the engine and then restart it the noise has gone - bizzare.
    As it is still under warranty I usually just wait for things to go bang or get a warning light, as the 'fitters' are no mechanics at my local VW garage. My local VW doesn't diagnose faults - just changes parts when they go bang.
    Thanks for your ideas and thoughts - may ring the garage in the next couple of days.
    Jamie
  5. Re: The Noise Machine
    May 2007
    Liverpool
    Alot of people don't know that, maybe the ******** don't tell you beause they coin it in when the turbo fails.
  6. Re: The Noise Machine
    Mar 2007
    Greater Manchester
    I've also read somewhere that you should let the turbo spool down after a long drive. Let the oil in the bearings (of the turbo) drain back into sump.
    I say I hav read this yet I don't act on it myself. 38 mile commute to work and I jut switch the engine off.
    How long should one leave it at idle?
    2001 Bora TDi PD 115 (AJM)
  7. Re: The Noise Machine
    Coventry
    If its under warranty take it to the dealer and take one of their bods out for a spin.
    I can't suggest enything else. There is no point. ITS UNDER WARRANTY - USE IT
  8. Re: The Noise Machine
    Coventry
    Quote Originally Posted by Loofer View Post
    Me too.
  9. Re: The Noise Machine
    May 2007
    Liverpool
    Between 30 and 60 seconds. Because the turbo is so hot if you just switch the engine off the oil that is on the bearings just dries out as the turbo still spins very fast, causing wear. By leaving the engine switched on for about 30-60 secs the oil can lubricate the bearings and the turbo can run down. Also not changing the oil regular enough can cause the bearings to fail too. Crappy oil prevents the correct lubrication. This happend to mine and the bearings failed/worn causing the whistle then the turbo detonated big time, at this point I had a little cry
  10. Re: The Noise Machine
    Mar 2007
    Greater Manchester
    Quote Originally Posted by chrisvrscrx View Post
    cheers for that... I think that unless people get to hear the science behind something (or they experience the repercussions of not doing it) they will never heed. I'll just try and get into the habit of remembering to let it cool down for a min or so.
    I'm guessing the same applies to when starting up the engine... allow the oil to warm up for say 60 seconds or so for better lubrication
    though I have read somewhere that in diesel engines, starting the car and leaving at idle has very little effect on warming up the engine... better of to just drive (gently)
    wotchu say bout thah?
  1. What's the noise?
    By Benners in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-08-2007, 10:24 PM
  2. 2.7 T -Ghost in the Machine
    By Big-Vern in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-08-2007, 04:27 AM
  3. got a noise
    By new to vw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2007, 05:02 PM
  4. Noise!!
    By Dips in forum Audi A3 - Archive Topics
    Last Post: 29-04-2007, 02:34 PM
  5. Audi 80tdi sewing machine
    By simyboye in forum 80 - 90
    Last Post: 26-01-2007, 07:45 PM
