Thread: PD's and bio diesel .Good or bad idea?
  1. PD's and bio diesel .Good or bad idea?
    Feb 2011
    preston,lancashire,england
    I have spent a good bit of time searching through posts about the using veg oil and bio diesel but still seem as perplexed as to whether to go for it.
    A lot of the posts were from years ago and more about using veg oil rather than good quality bio diesel.
    Some were saying that PD engines should not be run on bio diesel yet there are people who say they have been doing it without any problems for tens of thousands of miles.
    I have two passats a 2000 tdi sport and a 2002 130 tdi se. and was wondering if there is any new relevant info as regards using bio diesel in a PD engine.
    Will my 2000 be a PD or not?
    Cheers and have a good day all
  2. Re: PD's and bio diesel .Good or bad idea?
    Pembrokeshire
    22 Post(s)
    don't know about bio, nasty stuff, but the pd converts and runs very well on svo when fitted with a kit from elsbett.
  3. Re: PD's and bio diesel .Good or bad idea?
    Feb 2011
    Hello Zollaf i hope you are well.
    And how much is said kit from elsbett?
    Cheers for the reply.
  4. Re: PD's and bio diesel .Good or bad idea?
    Pembrokeshire
    22 Post(s)
    don't know but last i knew about a grand. elsbett seem to be hard to contact right now.
  5. Re: PD's and bio diesel .Good or bad idea?
    Feb 2011
    Thanks Zollaf.
    Jeepers that would take some getting back.why do you say bio is nasty stuff as i thought as it is processed veg oil that it would be wvo that would be the nastier.
    Have a good evening.
  6. Re: PD's and bio diesel .Good or bad idea?
    Pembrokeshire
    22 Post(s)
    the problem is with bio that it is veg oil washed down with nasty chemicals to break the structure of the oil to make it thinner. there are also a lot of cowboys out to make a quick buck not filtering it or making it properly. done right its ok, but you are still burning chemicals. svo or wvo is better because its just veg oil with a bit of filtering in the case of wvo, no added chemicals. yes the kits are a lot, but, take me for instance. i run on wvo at 60 p /litre. if i had the time to collect and process wvo then it would be a lot cheaper. thats 80p cheaper than dino. thats £64 on an 80 litre fill up. 20 tanks and the kits into profit. if you do the miles then it can save a lot of money. if you don't do a lot of miles then its not worth it.
  7. Re: PD's and bio diesel .Good or bad idea?
    Aug 2011
    Meath
    It's getting harder to find wvo and the real stuff is dearer than diesel in Ireland. You can buy properly made and tested bio-diesel in a few places but theres 2 problems, the first is simply that the fuel filter needs changed every 1000 miles or so, four or five times in a row as the bio loosens the crap and stuff from lines etc. keeping that in mind in Ireland it's 13c or less than 10p a litre cheaper, hardly worth the effort unless you are a person that likes beer with twigs in it and you cut your own hair
  1. Question 150 tdi upgrade to hybrid stage 2 good or bad idea?
    By rs250gpracer in forum Golf MK4 - 1999 - 2004
    Last Post: 20-04-2010, 09:21 AM
  2. Replies: 4
    Last Post: 11-03-2009, 06:05 PM
  3. GAP Insurance, A good or bad idea?
    By Wazza_G in forum Chat - Completely Off Topic
    Last Post: 09-09-2008, 01:55 PM
  4. good idea
    By a8 tech in forum Chat - Completely Off Topic
    Last Post: 08-05-2008, 08:11 PM
