Thread: BiTDI
Page 8 of 14 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 137
  1. Re: BiTDI
    #71
    Jan 2013
    Reading
    I have been taking it steady for the most part. It's surprising how relaxing it is actually, quite an effortless enjoyable ride. Glad I didn't go for the sports suspension though, the s-line suspension is just right and contrary to some opinions I quite like the non led air con temp dials.
    MY2015 RS7 V8 4.0L - Nogaro Blue
  2. Re: BiTDI
    #72
    Nov 2012
    Gothenburg, Sweden
    Update..I now use the paddles for overtaking quicker. I think there should be a TCU upgrade for the gearbox soon. Anyone heard anything? Or what you think about the Sprint Booster? Would that work?
    Skickat från min GT-I9505 via Tapatalk 2
    From Sweden - A6 (C7) BiTdi, S-line, Arctic white. Mercedes E-Class 250 Avantgard, Black, panorama roof and AMG rims. Corvette C6 Z06, yellow, 550 hp.
  3. Re: BiTDI
    #73
    May 2013
    Quote Originally Posted by DBLincoln View Post
    Hi Guys
    Best ‘take off’ appears to be in Comfort………..once slip has gone it flies but it is that slip lag that bothers me.
    DBLincoln
    Are you suggesting the gearbox is slipping? The performance upgrade sounds great, but concerning if it can cause problems.
  4. Re: BiTDI
    #74
    Apr 2013
    Bedfordshire
    Has any Bi-TDI owner seen any news/rumours on whether Audi are going to release a software upgrade for the gearbox to cure the 2nd to 1st jearky downchange and the kick-down responsiveness? Thanks Steve
    Steve
    VW Golf MK7 GTD 2014; Aud TT 2.0TDI Roadster Quattro 2008;
  5. Re: BiTDI
    #75
    jbanfie Guest
    Hi Steve, the short answer is no, and sadly, I think the long answer is no and never.
    I ran this whole issue up the flag pole a couple of months ago and got stumped by the 'type approval' statement, and was told to change the configuration of the car would require a re-type approval process which presumably costs quite a bit so they won't do it.
    Get yourself to Holland spend the 1250 Euros and love your car again.
    But in all seriousness, I now run in sport mode whenever I'm 'driving' or going to overtake when the road allows, this picks the revs up quite a bit, I then downshift one or two gears on the paddles as the opportunity arises and boot it, this tends to avoid stupid kick downs as you've done the work already.
    Be happy Bi-Turbo owners, be happy!
  6. Re: BiTDI
    #76
    Stratford upon Avon UK
    36 Post(s)
    My Allroad is just a few weeks old and still has the 'awkward' 2nd into 1st change (i.e. MY 2014 builds behave the same). You only really notice it when you turn into a side road and have to slow to a near halt... a rolling downshift, coming to a halt at intersections it is not evident.
    I'm completely with jbanfie on sports mode / paddles for 'spirited' driving - and this was also the case with my old C6 3.0 TDi. If you know you're pressing on then dynamic / sports mode is best with occasional use of the paddles. If you happen to be in Auto / comfort (or eco, although I can only see me using that on a motorway haul in winter) then use paddles to set up an overtake as it will prevent any auto gear shifts. Obviously if you're sitting for a while waiting for a gap just knock the box into manual to prevent it from 'reverting'.
    I can 'live' with that - in fact i consider it part of getting the best out of the machine (aka "driving" )
  7. Re: BiTDI
    #77
    jbanfie Guest
    And to be fair, as Steve noted in the other thread, I too can get 50mpg when I take it real easy - my conclusions are that you can't have your cake and eat it with Diesel cars, but this one gets pretty close and as we have all concluded you can easily live with the small compromises.
    The kick down could be better though - bah humbug!
  8. Re: BiTDI
    #78
    36 Post(s)
    EvilPostIt said "It's surprising how relaxing it is actually, quite an effortless enjoyable ride."
    Funny, exactly the comment that my wife made and I was trundling along using the torque below 2000 RPM... "it seems very effortless"
  9. Re: BiTDI
    #79
    Apr 2013
    Bedfordshire
    my wife and daughter both say ".....this car SCARES ME...(whilst holding the side of the seat)." generally when I've kicked it down a couple of gears manually and in the sweet-spot of 2000 revs plus for an 'express' join to the motorway :-) - but YES I can compromise too BUT would like Audi to fix-it just to make it a perfect all-round car...(I swapped a Merc SL for this car...)
    Steve
  10. Re: BiTDI
    #80
    May 2013
    Quote Originally Posted by ukgroucho View Post
    I was really interested in DBlincoln's remapping experience and some of the other discussion on the ZF HP8 gearbox in the A6 BiTdi derivatives (I'm on the brink of ordering an Allroad BiTdi - test drive on Monday). Anyway I started digging around and found a wiki article on teh engine and it got me wondering which specific HP8 gearbox does the BiTdi use. The wiki article (ZF 8HP transmission - Wikipedia, the free encyclopedia) claims the following
    List of ZF 8HP variants
    name max. gasoline torque (N·m) max. diesel torque (N·m) examples
    8HP30 300 300 -
    8HP45 450 500 BMW 1 Series (F20), BMW 5 Series (F10)
    8HP55 550 550 Audi A4 (B8), Audi A6 (C7)
    8HP70 700 700 BMW 7 Series (F01), BMW X5 (E70), Range Rover Sport (2012)
    8HP90 900 1000 Rolls-Royce Ghost,[21] Bentley Mulsanne
    Transmissions in blue are used by Chrysler.
    So the A6 (I assume BiTdi) has the 8HP55 - which is rated for 550N-m in a diesel ... seems odd given that the engine produces a max of 650 N-m. Makes me wonder if remapping the engine is a wise thing to do ..
    Anyone got any comments?
    Did you ever get any answers on this?!
    A6 Avant S-Line BiTdi | born Sept '13 | advanced tech pack | sports diff | privacy glass | 75l fuel tank | lighting pack | HB assist | rear cam
    Q5 S-Line Plus TFSI | born April '11 | tempted to add stage 1 Revo taking HP from 177 to 290.
  1. BiTdi exhaust soundtrack
    By robbyg in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-01-2015, 01:43 PM
  2. New BiTDI Three weeks in
    By BiTDI in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 29-09-2012, 09:36 AM
