Thread: Dashboard Display - boot showing open
  1. Dashboard Display - boot showing open
    Jan 2009
    I have Audi a4 (W2000) 1.9tdi, the display shows the boot is open, when it clearly is shut.
    I have just changed the whole boot lock mechanism (sensor/microswitch etc), thinking this was the problem, but to no avail.
    The problem is still there and is very annoying.
    The boot light is not working as well, could this the problem? (changed the bulb)
    Thanks in advance
  2. Re: Dashboard Display - boot showing open
    Sep 2012
    Cleveland, UK
    Have you had her on the VCDS?
    Could be a fault with the alarm sensor.
    James
  3. Re: Dashboard Display - boot showing open
    Jan 2009
    Quote Originally Posted by AudiDoDis View Post
    James
    Thanks, but what is VCDS (is that dianostics)? and how can i check if the alarm sensor is at fault?
  4. Re: Dashboard Display - boot showing open
    Sep 2012
    Cleveland, UK
    Quote Originally Posted by macaroon View Post
    VAG COM Diagnostics Software - yes diagnostic software, plug the car in, run the auto scan or specifically just check the relevant section, check the outcome when its finished, you will get a log file stating what's what.
    This thread has a list of all the members that have VAG-COM/VCDS and where they are located, there is also this map that has all the locations pinned, have a poke around and see if there is anyone near you.
  1. Please Help Front Doors Open No Longer Showing
    By VAG in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-02-2010, 03:12 PM
  2. Dashboard display
    By audia3hatch in forum Audi A3 - Archive Topics
    Last Post: 20-12-2008, 03:58 PM
  3. Replies: 5
    Last Post: 28-04-2008, 10:34 PM
  4. Dashboard Display
    By twotwo2pac in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-09-2007, 02:21 AM
  5. boot warning sensor comes on the display when the boot is shut
    By merchantmr in forum Audi A4 - Archive Topics
    Last Post: 06-02-2007, 10:04 PM
