Thread: A4 Quattro non start
  1. A4 Quattro non start
    Aug 2007
    Hi New member question, hope someone can help.
    A4 Quattro 1998 just fitted new clutch and flywheel and after completion the car will not start. At first thought that the flywheel was in wrong position but found that it can only fit in one place. Have checked flywheel sensor and all is ok. There is no fuel or ignition, also no live to the relevant fuses. It is as though the imobilizer is on. Also checked for trapped wires but none found. Any suggestions would be very helpful. Regards Brian.
  2. Re: A4 Quattro non start
    Canada
    The immobilser usually let the car fire then stops within a seconded are the igntion lights on, do you have a fault reader?
  3. Re: A4 Quattro non start
    Aug 2007
    Hi. We have a Scanner and there are no recorded faults or codes and we do have all ignition lights. Also have checked the fuel pump relay which is working.
    Regards Brian.
  4. Re: A4 Quattro non start
    Aug 2007
    Thank you any one who read the thread. We found the problem, the brand new flywheel didn't have a trigger ring probably down to bad manufacture. Completely missed it on assembly. Should have been more vigilant but you would expect it to be correct from a major supplier. Regards Brian
  5. Re: A4 Quattro non start
    Canada
    Thanks for updated the thread, Glad you have it sorted
  1. A6 TDI Quattro 1999 Will not start in the mornings? Please HELP.
    By dooley1414 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-05-2008, 06:28 PM
  2. MK3 TDI - Will not start?
    By pass&golf_tdi in forum Golf MK3 - 1993 - 1999
    Last Post: 05-06-2007, 10:49 AM
  3. S4 start up
    By aidanjaye in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-05-2007, 06:59 PM
  4. A4 Quattro - Cold Start Problems
    By Gogzie in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-01-2007, 10:47 AM
  5. How do you start yours???
    By vdub golf in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-12-2006, 02:26 PM
