Thread: Traction Control Light staying on
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Traction Control Light staying on
    46 Post(s)
    Try a full lock left to right once or twice and drive in a straight line.
    It *may* go off if the battery has drained and its lost its steering calibration.
  2. Re: Traction Control Light staying on
    Aug 2011
    Meath
    If the ESP had a fault code stored the ecu will assume it's not working, you don't try to turn on the light when you've been disconnected from the grid
  3. Re: Traction Control Light staying on
    Dec 2008
    N Ireland
    Get it on VCDS.
    I suspect that the ABS pump has failed. This is a well known fault with VAG cars especially if fitted with the Teeves mk60 abs pump. If you do a google search for this you will see what I mean.
    Rebuilt pumps can be bought on an exchange basis. I had the same problem with my car, the ESP light was on all the time but not the ABS light.
    Do google search for BBA reman, they supply rebuilt pumps, but first check the error codes and what they mean.
  1. Please Help ABS and Traction Control Light are staying on
    By coolruler in forum Touran - Sharan - Caravelle
    Last Post: 05-01-2013, 07:22 PM
  2. Please Help ABS an traction light staying on
    By volvofh in forum Golf MK5 - 2004 - 2009
    Last Post: 25-12-2010, 02:24 PM
  3. Traction Control Light
    By olnmfc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-10-2010, 04:01 PM
  4. Replies: 10
    Last Post: 28-06-2010, 09:12 PM
  5. Skoda Superb Traction Contol and ABS light staying on
    By irishfan72 in forum Archive posts
    Last Post: 04-01-2008, 05:22 PM
