Thread: 3M headlight restoration kit
Results 1 to 10 of 19
  1. 3M headlight restoration kit
    Jun 2008
    Lichfield, Staffordshire
    I bought a 3M headlight restoration kit off Ebay for £19 and got to work with my power drill.
    here are the before and after pics of the headlights, they look like new now.
    I wouldn't hesitate to recommend this product, the only scary thing is sanding the headlight down to start off but the end result is worth the panic moment !
    0 3 0
  2. Re: 3M headlight restoration kit
    Jun 2007
    Exactly which 3M kit did you use, there are several. Regards Peter
  3. Re: 3M headlight restoration kit
    Aug 2011
    Meath
    Very impressive, good job
  4. Re: 3M headlight restoration kit
    chester
    17 Post(s)
    I've often wondered whether those kits were any good,nice job,did that staining on the bumper come off ok.
    A4 B6,A4B7Quattro,MK4 Golf,MK5Golf gone and well forgotten,MK6Golf.
  5. Re: 3M headlight restoration kit
    Jun 2008
    Quote Originally Posted by nevo View Post
    The marks on the bumper is just wet plastic dust, it wipes off with a damp rag.
    The 3M kit was part number 39008.
    my mechanic said the headlights would probably fail the next MOT with the lights as they were so I am a happy chap.
    I have bought a HID lamp kit for my allroad but not sure if I need it now !
  6. Re: 3M headlight restoration kit
    Jun 2007
    That appears to be a KIT from the USA. Do you have an ebay link for the product. Regards Peter
  7. Re: 3M headlight restoration kit
    Jun 2008
    Hi Peter, the Ebay number 280976850957 should get you to an active item. The seller is based in Bedford but you are right, it's a USA product.
    There are other kits out there - Meguairs, I think Carplan do something similar and people say you can get a decent result with T-cut and a drill mounted polishing pad but I've not tried these options and for 19 quid why gamble ?
  8. Re: 3M headlight restoration kit
    Nov 2009
    46 Post(s)
    Quote Originally Posted by Golf tdi Hal View Post
    3M Headlight Lens Restoration System | eBay | 280976850957
  9. Re: 3M headlight restoration kit
    133 Post(s)
    1986 Post(s)
    I have used the Turtle Wax kit plus a spare drill mounted polishing pad and had excellent results. The Re-Gel kits are also very good.
    http://www.rejel.com/rejel-store/cat...%2cproductname
  10. Re: 3M headlight restoration kit
    Mar 2008
    High Wycombe
    Does anyone know how these compare to the Surf City product that a certain VWAudiforum is authorised reseller for?
    The Surf City one says 'no sanding', which sounds good but how does it work?
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  1. Question HID Kit... Only 1 headlight lighting up????
    By okam in forum Golf MK5 - 2004 - 2009
    Last Post: 13-11-2012, 04:47 PM
  2. Headlight tab repair kit
    By go-for-it1 in forum Golf MK5 - 2004 - 2009
    Last Post: 30-10-2011, 06:24 PM
