Thread: Audi Allroad 2.5tdi Auto - how to remove trim to get to brake light switch??Help!!
  1. Audi Allroad 2.5tdi Auto - how to remove trim to get to brake light switch??Help!!
    Hi Guys,
    I believe my brake light switch is kaput, to replace it, I need to remove the drivers side trim under the wheel. There are two 8mm bolts easily accessible but once they are removed the trim is still held. How do I get this damned thing off without breaking it?
  2. Re: Audi Allroad 2.5tdi Auto - how to remove trim to get to brake light switch??Help!!
    Jul 2011
    london uk
    hi
    i have removed my trim and i had 2 bolts on bottom of trim and 2 bolts below instrument cluster left and right of sterring wheel also but not sure i think there is a bolt on the side of dash where your fuses are located but not 100% sure as mine did not have one there but there is a hole for one hope this helps
  3. Re: Audi Allroad 2.5tdi Auto - how to remove trim to get to brake light switch??Help!!
    Nov 2011
    Duns Scotland
    11 Post(s)
    Hi. There are 5 bolts in total:
    1)Remove plastic trim at top of steering stalk behind steering wheel - simply lever/pull off.
    2)Remove plastic fuse cover driver's side end of dash - hidden when door is closed!
    3)Remove bolt (now revealed by removing fuse cover)
    4) Remove two bolts on top (now revealed behind steering wheel.
    5) Remove the two bottom bolts and gently remove and lay on floor the trim.
    Be aware, when installing the new brake light switch, you first turn 45 degrees to lock the switch in place - THEN TURN ANOTHER 45 DEGREES to prime the switch. This is different from the old switches which were locked and primed by only 45 degree turn. My manual still states only 45 degrees - but if you do not turn again, the switch won't prime!
  1. 3.0tdi Allroad brake fault alarm on switch on.
    By sparker in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 30-12-2012, 11:22 PM
  2. 'Slipping' Auto gearbox 2.5TDi Allroad?
    By toadus in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-03-2011, 03:31 PM
  3. Replies: 0
    Last Post: 09-01-2011, 12:44 PM
  4. 02 Audi A6 ESP/Brake light switch question
    By schoelman in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-12-2006, 11:44 PM
