Thread: ASR (traction control) overactive with 18" wheel upgrade
Results 1 to 8 of 8
  1. ASR (traction control) overactive with 18" wheel upgrade
    Oct 2012
    Clacton on sea, Essex
    Hi all
    I have a 1998 2.5tdi Audi A6 Avant. When I bought the old girl she had 16" alloys. I have fitted 18" Audi Alloys and now the car is impossible to drive with the Traction Control active. If you turn of the traction control it drives as it should. The front wheels are 225/40/18 and the rears are 245/40/18.
    Could anyone shed any light on how I can get the traction control to behave?
    Many thanks
  2. Re: ASR (traction control) overactive with 18" wheel upgrade
    Aug 2011
    Meath
    Hi Stephen
    were any of the abs sensors disturbed when the wheels were changed, can you get the car scanned (VCDS) changing the wheel size shouldn't make a difference to traction/abs
  3. Re: ASR (traction control) overactive with 18" wheel upgrade
    Mar 2008
    High Wycombe
    You've got different sized tyres front and rear. My quick calculations show you've gone from a factory wheel radius of 316mm to 318.6 on the front, and 326.6 on the rear. Your wheel speeds will therefore be 2.5% different from front to rear (your speed sensors will be saying the fronts are going 2.5% faster than the rears). I'm not sure if this is enough to trip the ASR into thinking you're starting to wheelspin, but it seems that it is. You can calculate this better by finding out the actual rolling radius / rolling circumference of the specific tyres. Companies like Michelin will publish this, but the likes of DiYung tyres probably haven't even heard of it.
    I'd say you're best of changing the rear tyres to match the same size as the front.
    You can check the wheel speeds using measuring blocks and data logging in VCDS/vagcom.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  4. Re: ASR (traction control) overactive with 18" wheel upgrade
    Aug 2011
    Meath
    Quote Originally Posted by NickPicks View Post
    Well spotted Nick I assumed the circumference would be the same on all the wheels, dragsters excluded. I must read more slowly!
  5. Re: ASR (traction control) overactive with 18" wheel upgrade
    Yep they all have to be the same size or at least rolling radius. When I reverse down my fairly steep drive my N/S rear tyre drives over a slightly raised drain cover and as the brakes are on the ABS kicks in for a split second. Does it most days. If it does that on a 1cm drain cover it sure will do it with those profiles. Regards Peter
  6. Re: ASR (traction control) overactive with 18" wheel upgrade
    May 2012
    Glasgow
    I've been running 18' rs6 reps with no probs for 4 months, tyres all same size tho and only very slightly larger rolling radius, I'd try same sizes all round as has been mentioned
    2001 A6 Avant 1.9tdi 130 manual AWX 203k+++ "Come to kindly terms with your @ss for it bears you." - John Muir.
  7. Re: ASR (traction control) overactive with 18" wheel upgrade
    Mar 2008
    High Wycombe
    It's not having a different size that causes a problem - it's having different sizes mixed together, although there must be some tolerance in the system, just don't know how much.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  8. Re: ASR (traction control) overactive with 18" wheel upgrade
    May 2012
    Glasgow
    Thats what i meant, same size all round rather than different size front and rear
  1. Air Con "ECON" & "AC" Control
    By golf144 in forum Golf MK5 - 2004 - 2009
    Last Post: 09-04-2011, 08:44 PM
  2. 17" Wheel upgrade offer
    By Jabamusic in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-07-2009, 04:41 PM
  3. 15" to 17" wheel upgrade....Need lowering???
    By Doctor-X in forum Wheels and Tyres
    Last Post: 04-12-2008, 09:14 AM
  4. "ASR" what is it?
    By elsid in forum Golf MK4 - 1999 - 2004
    Last Post: 26-04-2008, 08:07 PM
  5. ASR/Traction Control
    By Cara2007 in forum Archive posts
    Last Post: 01-04-2007, 09:47 AM
